Headlight Upgrades
Old 04-03-2017, 07:51 PM
dsimon55
dsimon55's Avatar
Default Headlight Upgrades
Hi
I want to upgrade the headlight on my 1985.
I have Sylvania Silverstone bulbs now
Have been looking at LED's
What has anyone done? Opinions?
Options?
Old 04-03-2017, 09:03 PM
Need A Vette
Need A Vette's Avatar
Gonna have to follow this thread, as I want to go to LEDs as well. For their superior light output, and less current drain!
D.
Old 04-03-2017, 09:23 PM
aklim
aklim's Avatar
Received 2,224 Likes on 1,938 Posts
https://www.corvetteforum.com/forums...ht-to-led.html
Old 04-04-2017, 04:51 AM
exitwound
exitwound's Avatar
Hi..
Problem with LED lamps is that they don't have much of a 'throw' of light although they do look brighter.
I have an '87 and totally transformed the headlamp's output and beam using these crystal ones. The front glass is flat and all the reflecting is done inside so even with a stock H4 bulb, the light 'throw' is 100% better that the stock C4 lamp.
I did fit an LED sidelamp bulb as it means a dismantle to replace a regular bulb, although the H4's are an easy fit.
I assume you can get these in the USA..
http://www.ebay.co.uk/itm/Pair-of-Cr...UAAOSw4GVYKaQU
Old 04-04-2017, 07:20 AM
aklim
aklim's Avatar
Originally Posted by exitwound
Hi..
How much throw are you looking for? I like the bright spot to be about 30 feet from me otherwise it gets too high and blinds other drivers who flash their high beams at me and that gets old after a while.
Old 04-04-2017, 10:05 AM
FAUEE
FAUEE's Avatar
Received 4,436 Likes on 2,797 Posts
My cheap amazon LED headlights throw pretty decent, especially in high beams. It throws better than the halogens I took out, but definitely is not up to the level of the HIDS in my c6.
if I drove it a lot at night I would get the nicer LED units like truck lite or one of those with the projector setup.
Old 04-04-2017, 02:53 PM
dsimon55
dsimon55's Avatar
Has anyone installed the Gennsi Projector LED H6054 lights?
Part # GEN-7X6PRO
do they just drop in and hook up or do they require some extra wiring?
Old 04-04-2017, 04:30 PM
85 Stalker
85 Stalker's Avatar
D.
I need to watch this thread too. I still have the original bulbs in my 85 and want to upgrade with a plug-n-play bulb.
Old 04-04-2017, 04:34 PM
aklim
aklim's Avatar
Part # GEN-7X6PRO
See post 3. I did it and got it to work with the pair of resistors.
Old 04-04-2017, 04:35 PM
aklim
aklim's Avatar
It wasn't PnP but reasonably easy
Old 04-04-2017, 04:53 PM
85 Stalker
85 Stalker's Avatar
What is the "Circuit Doctor?"
A supplier of lights that will not require resistors?
Old 04-04-2017, 04:57 PM
aklim
aklim's Avatar
Not sure but I think most of them will since their resistance is lower than the HID or incandescent. It is a resistance in line but I prefer the cleaner installation instead of cutting and soldered wire so I got those resistance things.
Old 04-04-2017, 05:03 PM
85 Stalker
85 Stalker's Avatar
Sorry to bug you and jack the thread -- do you happen to still have the part number for the light and the resistors?
Old 04-04-2017, 05:07 PM
aklim
aklim's Avatar
https://www.superbrightleds.com/moreinfo/flashers-load-resistors/headlight-load-resistor-kit-h4-led-headlight-bulbs/2179/
He was talking about the Genssi 7X6Pro
85 Stalker (04-04-2017)
Old 04-04-2017, 05:10 PM
aklim
aklim's Avatar
Genssi 7X6Pro http://www.ebay.com/itm/162081918608
Old 04-04-2017, 09:58 PM
gdl2165
gdl2165's Avatar
Hi..
I must disagree with this statement, it depends entirely on which LED lights you get. The JW Speaker lights are absolutely fantastic, although very pricey. Truck-Lites, which I have, are nearly the equal of the JW Speakers at a more reasonable price point. The pics I've seen of the new Genssi lights look pretty good and they're even less expensive. I will agree that if you do the generic housings intended for
halogen bulbs and put the LED replacements into them you're not going to get very good results.
Truck-Lite Low Beam
Truck-Lite High Beam
Old 04-05-2017, 04:12 AM
Cliff Harris
Cliff Harris's Avatar
The resistors/Circuit Doctor mod are only needed if you have a 1990 or newer car that uses the high beam filament to ground the fog lights. Since LEDs don't have a filament, there is no ground path for the fog lights. Older cars have the fog lights grounded directly, so they don't have the problem.
See this thread for the full explanation:
https://www.corvetteforum.com/forums...-solution.html
To Headlight Upgrades
Old 04-05-2017, 08:15 PM
jsinga
jsinga's Avatar
http://www.danielsternlighting.com/home.html
The Cibie lamps, 130/100 bulbs, new wiring and a relay kit will give you real headlights you can see with. Will have both high and low beam and put light on the road and not in on-coming drivers. @ $250 and a day. They really work
JS
Old 04-06-2017, 12:27 AM
aklim
aklim's Avatar
JS
Are you sure that is legal? That looks kinda brighter than legal limits
Old 04-06-2017, 08:31 AM
Nokones
Nokones's Avatar
Here's my C4 headlight upgrade.
Quick Reply: Headlight Upgrades
