Climate control unit
I have a 1990 corvette and the climate control unit is displaying - -- the blower is stuck on high and the buttons don't respond. I tried cleaning the contacts but it didn't change anything. Any idea what is wrong
There is a YouTube video that addresses that very problem for your car. Search for Climate control repair-C4 corvette. I need to do this to my 1993 coupe. Good luck! Seems pretty easy to do.
You have already cleaned the contacts on your climate control switches so this is what I would look at next.
Good luck!
You might try checking the blend door module located under the passenger side dash area. I disassembled mine and found the main nylon gear cracked. The gear is press fit on the metal shaft from the factory and over time it splits and causes the timing to go off. I repaired mine because I couldn't find a replacement that would fit my 1996.
Good luck!
Good luck!
OP can you get the HVAC panel into diagnostic mode?
