C4 radiator replacement with a 2 core unit
Hi
Pay careful attention to the core size, the standard radiator has a 1 inch thick single row core.
Some sellers may say double row but are only 2x 1/2 inch rows ,
2x 1 inch rows is what you want.
Be careful of cheap Chinese ones that have thin aluminum rows that expand and restrict airflow.
It cost me the same in postage in overseas freight for a double row one on ebay,it had restrictions the ends of the core was folded over would not flow enough coolant.
It was as much as another radiator to post it back, Purchased another one after some members recommended them that has been good.
Dewitts double row are the best but cost $500.... they have a cheaper 1.5 inch single row radiator also.
Search google and do some research.
You need to modify the rubber radiator mounts to accommodate the thicker radiator.
The DeWitt's radiators come with the correct radiator mounts already cut.
On radiators, more is not necessarily better. flow is as important as surface area. One core aluminums generally have more surface area than two core (measure the width of the one core and then the total width of the two core - not the distance from front of first core to rear of second core.) Less cores mean less restriction, both in fluid throughput and air over cores.
