stripped a runner bolt...now what
Trying to get the runner off to remove the fuel rail. unfortunately, I think I stripped a b ilt off in the lower runner. Any ideas how to get that ***** out?
Drifter36 (06-25-2017)
When I was working at Epson and had a rounded hex head bolt on a machine I would try this. I'd take the correct size allen wrench and grind the end flat on the grinder wheel. This would give the allen wrench end a bit of a "tooth" that would grip the bottom of the hex in the bolt head. That got many lower torqued bolts loose for me on the production floor. Maybe you could try that with the torx wrench. Grind the end flat and don't clean up the edges. Tap it in and pray. Works sometimes. I've also tapped a flat blade screw driver down into the head and turned the screwdriver while tapping on the end of the handle. You'd be surprised what ends up working when you're desperate.
When I've been desperate I've drilled bolt heads off. Leaves a short "stud" you can turn out once everything is out of the way. I don't know what the experienced guys with this engine would say though. These have worked for me. Maybe put hex cap screws in too when replacing the runners. I hate the torx bolts.
Went
Went
I think before I'd drill off the head etc., I'd spray it down with Kroil or comparable then try getting an impact torx and an extension and first try driving it into the head of the bolt. Use an impact wrench and lean into it and see if you can break it loose.
It's possible a little heat might help it along also.
Good luck.
Good luck.
Went
Went
Good luck.
Good luck.
I wasn't saying whack it with a hammer. Just some light tapping while you turn will help break loose a bolt head many times where turning the tool alone fails. You have to be mindful of the materials you are working with.
from the pic, the torx recess doesn't look that bad. one thing with torx bolts, you need to go in straight and squarely with the torx socket. that maximizes the torque and minimizes stress on the (torx) recess. any angle amplifies any potential problems. if I recall, the valve cover and injector harness/trim, interfere with a straight shot into the bottom runner bolts. try getting better access the bottom bolts, in other words, remove the injector harness and the RH valve cover. (just my 2-cents)
I would take it to a good Vette tech and let him take care of it. Some of these guys work magic with problems like yours. If it doesn't run put it on a flat bed. Most auto insurance covers this up to 100-200$
Use the next sized torx head and tap it into the bolt. It should be snug and should come out nicely. You won't hurt the intake or runners doing this.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Got to have that torq's straight on.
Nathan Lord, So I am curious. Did you get the bolt out?
Go to your local car parts store. Tell the tech what size bolt you're working on. Tell him you want a corresponding "easy out." This is a threading tool that you will thread into a hole you drill into the center of the stripped bolt head. This tool has reverse thread cutters made of case hardened steel. Once the hole is drilled, carefully insert this tool into the top of the bolt, and turn it counterclockwise. The "easy out" will dig into the drilled hole, so keep carefully turning the tool until it bottoms out. Now apply a suitable wrench to the top of the "easy out" and keep turning counterclockwise until the stripped bolt is removed.
VikingTrad3r (06-26-2017)
Very cool.
Went
Went
Rule #2- Obey all rules.
