84 A/C system wiring
Afternoon all,
I've been tracking down a problem with the cooling fan on my '84 that's been causing it to run all the time, even with the A/C off and the engine cold and not running. The ground side of the fan control relay coil is getting a constant ground, even with the coolant temp sensor and both A/C pressure switches unplugged. I think I found the problem (a wire nut tying a wire near the A/C compressor to ground) but was wondering if someone had an electrical wiring diagram for the A/C system and where the cooling fan relay circuit ties in (I'm assuming the low pressure switch). I have the diagram for the fan relay circuit, but can't find the A/C system.
Thanks,
Reed
Thanks,
Reed
Sounds like previous owner grounded out fan.Undo the wire nut to ground and drive the car. Fan should come on @235.
That's probably a good idea to verify that the temp sensor works since I just replaced it (old one had broken and was partially melted to a header). I think my current plan is to wire a relay in parallel between the high pressure A/C switch and the compressor, and use the relay to close the ground when the compressor turns on, ensuring the fan comes on when the A/C comes on. It's a more complicated solution, but it restores the full function of the cooling fan.
Thanks,
Reed
Thanks,
Reed
The cooling fan relay is located on the left side inner wheel well
The a/c pressure switch is located on the top left (drivers) side of the compressor, and has a "pinch" style connector.
Why do you need an additional relay? Your diagram is correct. You only need one relay. Is there some confusion about the a/c pressure switch in your compressor? It's NOT the "high pressure safety cut-out switch".
Thanks,
Reed
Thanks,
Reed
