Brake booster change on a 96..any tips
I have changed all brake pads, turned rotors, flushed old brake fluid, and checked booster check valve. Pedal is heavy and no forward movement during booster test. Brake lines look good. So here we go..gonna change the booster. Any tips from the forum?? Guy on you tube says remove seat as well as panel under dash. Seat if your fairly. I don't want to do that unless you guys don't think it's accessible by removing under dash panel.
Dude that's an amazing body of work there. After being told by dealership it would be approximately $850 to change booster I realized this would be another time that I would learn to do it and save some money. Much like changing my rear hub bearings was an intimidating task until I got to wrenching and realized it wasn't that hard this job to is a bit intimidating. That how to post gave a good idea of how to approach the task...Thanks!!
