Bose radio in a 93 ragtop
Hi vette owners, I recently realized that the speakers on the driver side seem weak compared to the passenger side, as a matter of fact the rear ds seems inoperative while the front ds has output but not a lot of bass. has anyone ever experienced this type of problem and if so what was the fix
Thanks Mark 970, I have a replacement speaker complete with amp. before I get too out of hand I think i'll remove the right side front and plug it into the left side and see if the same problem exists. I guess my concern was that maybe the signal from the main unit might be weak, is it strictly the speaker amps that control the output to each speaker or are there individual outputs to each speaker amp from the main unit in addition to there being individual amps?
There is another device used between the head unit and the speakers...it's located in one of the rear floor compartments but i'm not sure how often that goes bad...for both my C4's it was the amps. One of them was lacking bass but it was loud and the other had almost no sound from the rears at all. i will have the videos online in about 15min
Espy1949 (07-18-2017)
On my '92 the CDM was bad and one front amp was bad. The head unit also did not play the CDs. I replaced the head unit with a double DIN pioneer, bypassed the CDM with a pre-made wiring harness and replaced bad front amp. After a week or two the other amp got very noisy and had to replace it too. Now it all sounds very good.
