1984 C4 No power Locks Horn Radio or antenna
Hi
I am new to this forum I own 1984 C4 and my bose speakers did not work. Radio acted like it worked so I changed the relay behind the information center. No luck all I got was a loud hum from the speakers.
as the battery on the car was draining I put on a battery charger but never switched it from trickle to 6 amps I killed the battery. Put the car on charge car would not start so I disconnected the battery waited 30 seconds and reconnected the battery. The car started Now the following doesn't work anymore Power door locks antenna radio the key in the ignition chime. or the interior lights . Checked all the fuses and they were good. What did I do???
Hi
jim8400 (07-19-2017)
absolutely perfect must be some corrosion in the fuse holder the fuse I took out 15 amp mini was good I put in a fresh one and everything back to life I cant thank you enough
Now do I try the bose relay swap again one person said that if I got the amplifier hum and no radio one of the speakers is bad.
My ac vents don't change and trying to get at the vac lines through the front isn't working the manual ac and the lines are in there like guitar strings no room. Ive read its usually the main vac line from firewall to the interior ??
In back of the radio and ac controls there are vac lines. Mine got eaten by mice and defrost vent for one wouldn't change.
jim8400 (07-21-2017)
Ive changed the vac check valve and no change
I need to take the interior panels down and see if a line has been munched.
As far as the radio it looks like it works the clock functions it seeks a station
but I haven't heard it play.
Don't think it's the relay. There would be no sound at all if that was it.
I've had radios in my shop that do as you describe. Try wriggling all the ***** and sliders with the volume up. If that doesn't help, I think it an internal problem with the radio.
This control less/rear defog looks pretty complete. This is what the rear of your control will look like. You can ZOOM etc. If you pull the control to only gain access you could likely diagnose better. i ain't the seller and don't know or recommend the seller. I thought it a good look at what to expect.
http://www.ebay.com/itm/1984-1989-Co...BZB4i6&vxp=mtr
