Dielectric Grease
86couper (07-24-2017)
decide for yourself -
https://www.nyelubricants.com/stuff/...tors_final.pdf
BTW - this is my personal choice for di-electric grease.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Also use it on weatherstripping.
YES. Although technically an insulator, it prevents the contacts from oxidation and thus suppresses the formation of carbon residue due to arcing.
It also provides some lubrication, and as We Gone points out, it is a fair weatherstripping protectant, especially in Weatherpak (connector) seals, etc.
It's good stuff!
It's good stuff!
Di-electric grease is essentially silicone paste. Silicone paste has lots of uses as a lubricant (brake slides, spark plug boots, weather
strips, etc.. and insulator and many times costs less the di-electric grease. Di-electric some how means a 2 oz tube costs more than a 6 oz tube of silicone paste at the hardware store.
still working on an 8 oz. jar I bought back in the late 70's. good thing this stuff doesn't have a shelf life -
St. Jude Donor '16
https://en.wikipedia.org/wiki/Silicone_grease
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Why anyone would put it on electrical connections of any kind is beyond me....if anything, I'd put electrically conductive grease on connectors.
Dielectric grease does not promote electric current. Quite the opposite, it resists current flow, i.e. it is electrically insulating.
you are correct, and (no flames) also wrong at the same time. I think we're getting off track here on the use of di-electric grease and the terminology. pretty sure the OP is saying on "electrical connectors," meaning, to use as a (weather) protective sealant on multi-pin connections (multi-pin - keyword)- at least that's the way I read it. on a multi-pin connector, you would not want to use a conductive grease as a sealant. for example, on a multi-pin light bulb, like a parking light/brake light/turn signal bulb that's exposed to the elements. you would want to weather-proof and lubricate the connection without adding a conductive path. the general's been doing this for years, and I think the general's been using di-electric grease on various under-hood relay connectors - at least on my C4. i'm trying to think of the havoc the OP would have if using conductive grease on a 4-pin relay connector - di-electric grease is typically used to weather-proof and lubricate the connection and protect it from the elements and not as a conductive aid - unless MY thinking is wrong.
FASTAZU (07-30-2017)
Finalist 2020 C4 of the Year - Unmodified
Oh yes. It's not just weather, it also helps keep oxygen etc from corroding the pins, prevents any movement from rubbing metal away and brings little angels to watch over the wires.
