Hose from throttle body to
valve cover on passenger side. What is the purpose of this hose it goes from throttle body to valve cover. Mechanic has put a cap on it and said to just put a filter in the hole in the valve cover left by removing the hose.
I assume you're referring to the EGR valve connection or a breather (Don't remember which is on which side of the engine). If it is, I wouldn't but that's my choice for emissions.
canuck buick (07-24-2017)
If you leave it that way, you will have fumes in the engine bay and it has a messy oil film. BTDT. So unless you want to route it to the exhaust pipe, it will make your engine bay greasy. I put 2 filters in the PCV and that. Both VCs had oil film around it and dirty from dust sticking.
The air that goes through the connection from the throttle body to the valve cover is metered air (it has gone through the MAF and been measured). When the PCV valve feeds this air into the intake manifold it will help maintain the correct AFR.
