Any ideas what this is????
Chasing a " no turn signal issue ". 4 ways work ( no dash indicators ). Turn signals illuminate, no flas, no dash indicators. Pulled the center dash, found the 4 way flasher can, pulled what I thought was the turn signal flasher, except it has 3 spade plug. With this pulled, turn signals still illuminate. Obviously it isn't the flasher. What is it.....has TRW , made in Canada, plus the numbers shown ???????
This is right next to the 4 way flasher can in a similar bracket, located behind the info center.
Horn relay! You didn't mention year but generally in a C4 (early) and the location you suggest I'm quite sure. Part# matches.
Directional/turn flasher is different than the hazard. Location in early C4 is generally right side of dash closer to the fuse box or ECM vicinity.
skyhawk50 (07-24-2017)
Thanks WVZR-1. Its a 1988 base.
Horn is my next project. These plastic cars just follow me home. I rescued this car last week from a total imbecile that thought a Corvette would be a nice car for his daughter to take to College this Fall ?????
