1984 replacing bose with non-bose system
Hello. I've asked questions similar to this before, but perhaps not as clearly. My goal is to replace the Bose system in my 1984 with a more modern non-bose system. Radio, and speakers both. My system doesn't work, and all components are 30+ yrs old so need replacement in any case.
I'm not after anything exotic, just a solid, cosmetically stock looking install that plays well. I will use the Retro Sound Newport (non-bose version) receiver, as its direct fit 1.5 Din, looks close to stock, and has upgraded features such as blue tooth and a usb port. Simple enough.
I will also replace door and rear speakers with traditional 2 or 3-way non bose speakers. My questions are:
(1) Does anyone have experience with this type of conversion and what is your advice?
(2) What size speakers will fit into the door and rear deck area with minor mods to the bose speaker mounts?
(3) What advice on receiver/car wiring changes to accept the non bose unit in the dash board to power the unit and operate the power antenna?
(4) Will I need to run all new speaker wire, or can I use the existing wires between the bose receiver and the speaker locations for the purpose of speaker wires?
Thanks for any info provided.
Received 1,596 Likes
I put 6 1/2" speakers in the doors, but I had to make a mounting plate and trim the stock opening about 1/2" to clear them. I also had to push the stock grills out 1/2" to clear the tweeters. The rears were a drop in affair in the cubbies behind the seats, but your coupe may be different.
You can only reuse the stock
power/ground/memory/power antenna wires, so any GM adapter for that era will work.
Some here will say differently, but you should run new speaker wires. The stock wiring was designed to only carry a low power signal to the Bose amps. Use a electrical snake or coat hanger to get the new wires from the doors to the dash, starting on the door side first. I ran the wires for the rear speakers under the console, a coupe might be different.
garyc4 (08-03-2017)
I did 6" in the front and 6x9 in the rear. I ripped out all the factory crap except the power antenna but you can use the factory power wiring. Again I did all new speaker wire. I did have an advantage as I replaced my interior at the same time so I cut my door panels to fit my new speakers. You can take the stock box out of the door and make your own plate to mount the speaker then use the stock speaker covers. On the rears the 6x9 uses the stock box with some creative cutting.
garyc4 (08-03-2017)
Great info, thanks to both of you. As you mentioned, I am also completely replacing the interior, so by doing the swap now I will have better access as you describe. I'd like to use the read deck stock coupe speaker locations so will need to trace the wiring path for that to put new speaker wires.
This: https://www.retromanufacturing.com/p...nt=31559204494. It's the closest thing to a factory look and has Apple compatibility, Bluetooth and USB inputs. I have experience with these radios, and they are really nice and sound really good. But you have to get an adapter for the Bose amplified speakers to work - you can find those on Amazon or eBay.
You may be able to pull new wires by firmly attaching them to the old.
My refit was way more work, being more 'exotic', but well work the effort in making new speaker boxes, etc.
It's less than 3 inches deep, so I'm wondering whether it would fit vertically behind the passenger seat. Just a thought..............
