Hood Paint Suggestions
Old 08-17-2017, 10:53 AM
funtoy
funtoy's Avatar
Default Hood Paint Suggestions
Painting my hood today, so what would you recommend for the type of paint? Rattle can, or ???
Gloss or Flat??
Rustoleum or POR15??
Old 08-17-2017, 03:07 PM
Patsgarage
Patsgarage's Avatar
Received 1,596 Likes on 1,074 Posts
Gloss or flat is your preference, POR 15 would be overkill, I would probably use engine or grill paint out of a rattle can because of the heat.
funtoy (08-17-2017)
Old 08-17-2017, 03:52 PM
drcook
drcook's Avatar
Finalist 2020 C4 of the Year - Modified
I would not use Rustoleum of POR 15 (P aint O ver R ust 15, car is fiberglass......POR15 very expensive).
Rustoleum would not be easy to paint over due to its formulation unless you used more Rustoleum should you choose to redo it in the future.
I 2nd this motion.
funtoy (08-17-2017)
Old 08-17-2017, 07:56 PM
funtoy
funtoy's Avatar
So I decided to go with duplicolor high heat engine paint and high heat primer. So after wet sanding several times here it is in primer.
Tomorrow will be 1st coat of black.
Old 08-17-2017, 08:01 PM
85 Stalker
85 Stalker's Avatar
If you are planning to hide the light wires in the support structure now would be a good time to drill the holes for routing (before you paint).
I used Krylon flat black on mine and it looks just like factory. Best part is if you need to touch it up you will never see it.
funtoy (08-17-2017)
Old 08-18-2017, 01:53 PM
corvetteronw
Support Corvetteforum!
corvetteronw's Avatar
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Body color
Old 08-18-2017, 02:49 PM
Patsgarage
Patsgarage's Avatar
Originally Posted by corvetteronw
Body color
I did not think I would like that, but it looks pretty cool.
Old 08-18-2017, 05:28 PM
funtoy
funtoy's Avatar
Love this, however I am not prepared to do anything other than rattle can. When I complete my garage, I hope to have my air compressor hooked up and paint tools etc..
Old 08-18-2017, 05:29 PM
funtoy
funtoy's Avatar
1st coat of paint complete. Going to finish 2nd on Monday.
Old 08-18-2017, 09:32 PM
HAD2HAV2
HAD2HAV2's Avatar
Looks good so far. What exterior color is on the hood edge? Are you re-painting this also?
I have a white exterior so I couldn't paint the inner hood that color because of dirt and grime.
Old 08-18-2017, 10:10 PM
pologreen1
pologreen1's Avatar
I think you need at least 2 more coats and maybe hold it back a couple more inches, and do full sweeps.
it will nice either way.
Old 08-19-2017, 08:31 AM
85 Stalker
85 Stalker's Avatar
Lookin' good so far!!!! Nice job!
To Hood Paint Suggestions
Quick Reply: Hood Paint Suggestions
