C6 equivalent muffler for C4
Received 3,043 Likes
St. Jude Donor '05
any stock or turbo style muffler, his will never sound like a C6 as its a Gen 1.
The more power you have the louder it gets under WOT
Are you talking about the dual mode NPP exhaust where based on rpm a valve opens to a louder bypass? B&B makes their fusion exhaust that works like that. Not sure on the specifics of the install (ie, can you set the trigger point, do you run wiring pr vacuum to the back, etc).
You can usually find NPP take off mufflers reasomably, and I'm sure you could build a system to operate them with tach signal and a small iv and valving.
Pro Mechanic
Fact is the LS cylinder firing order is different:
LS = 18726543*
Except LS = 18436572
*Same cylinder firing order as the Ford modular motors, except Ford's cylinder numbering scheme is different.
Banned Loser
Location: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Mufflers? We don't need no stinkin' mufflers
hockeyhead019 (08-21-2017)
