TPiS Air Pump Delete failed
Old 08-22-2017, 09:30 PM
Bogdan
Bogdan's Avatar
Default TPiS Air Pump Delete failed
Has anyone used this kit and had it break within less than 30 days? I paid $175 for it and it snapped in half between the engine mount and the pulley today. Baffled as to why other than defective part or poor installation by a local garage. Looking for helpful answers on alternative parts or just replacing it with same part.
Old 08-22-2017, 10:07 PM
vader86
vader86's Avatar
Received 1,398 Likes on 1,015 Posts
I bought mine back in the day from Breathless, seemed sturdy enough that it wouldnt break where yours is breaking. I do not know if they still make it.
Old 08-22-2017, 10:29 PM
aklim
aklim's Avatar
Received 2,214 Likes on 1,928 Posts
Where did you get it from? Get another from TPIS and see. It's not like this could not be a fluke. Either that or the installed FUBARed the thing.
Old 08-23-2017, 09:21 AM
OldGyrene
OldGyrene's Avatar
if you still have the air pump mounting bracket, make your own delete or have it made. I made mine and it is SOLID and I like the look better than that erector set. New belt is required, but length was fairly simple to determine.
Old 08-23-2017, 09:43 AM
Raidmagic
Raidmagic's Avatar
Did you contact the seller? That would be my first step.
Old 08-26-2017, 08:55 AM
Bogdan
Bogdan's Avatar
Thanks for responding. TPiS sent me a replacement bracket. If this one fails than I will have one made or use my old bracket and have it modified. Hopeful.
Old 08-26-2017, 08:56 AM
Bogdan
Bogdan's Avatar
Yes and they sent me a new bracket. They were surprised by the break and said they had not seen it break before. Shipping costs only so not a bad solution.
Old 08-26-2017, 08:58 AM
Bogdan
Bogdan's Avatar
Great idea if the replacement bracket fails. Still have the original parts which frankly looked better. How do you keep your engine so clean, steam cleaning?
Old 08-26-2017, 09:00 AM
Bogdan
Bogdan's Avatar
Had to wonder if it was installed poorly, hope not on the replacement bracket as this is simple stuff to install. We shall see what happens next. May decide to have a titanium bracket made if it breaks again.
Old 08-26-2017, 09:02 AM
Bogdan
Bogdan's Avatar
Just so the picture tells the story!
Old 08-26-2017, 09:04 AM
Bogdan
Bogdan's Avatar
Any suggestions on fixing a timing chain cover gasket anti-freeze leak that developed after replacing the radiator and flushing the engine would be appreciated. New low fluid level sensor like the original goes on even when the radiator was full. Hmmm?
Old 08-26-2017, 09:35 AM
OldGyrene
OldGyrene's Avatar
Nope. Just lots of long winter days with brushes & Simple Green. Oh, and a few beers !
Old 08-26-2017, 10:24 AM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
The timing cover will leak oil, not antifreeze.
Old 08-26-2017, 03:57 PM
Benny42
Benny42's Avatar
Make sure the bracket is installed in the proper order. If the new one isn't aligned properly it will break too. Look at the instruction sheet closely as to the proper order the 3 parts are assembled.
Old 08-26-2017, 11:08 PM
aklim
aklim's Avatar
Is there a brace that should be there? I forgot.
Old 08-27-2017, 09:36 AM
C409
C409's Avatar
..... Mine is from Breathless Performance and has to be 12 years old ... solid aluminum bars ... no holes or slots for "weight saving" to weaken the brackets so they can break where yours did ... the 2 smaller holes to the left of the pulley momentarily held my adjustable fuel pressure regulator until I decided that I didn't like the idea of a fuel source just above my alternator .....
Old 08-27-2017, 09:37 AM
C409
C409's Avatar
..... Anti-freeze in that area is usually from the weep hole on the bottom of the water pump ... time for a new one .....
Old 08-28-2017, 07:18 PM
TA
TA's Avatar
http://breathlessracing.com/index.ph...&productId=843
This is the one I've had on my car for 15+ years without any issues. I guess the only thing I don't like is that the black finish has purpled a bit over the years.
To TPiS Air Pump Delete failed
Quick Reply: TPiS Air Pump Delete failed
