ECM wire harness disconnect
Have 93 ECM wire harness to disconnect. Has clips that should be spread apart to disengage. Don't want to break plastic clips. Attached pic. Any help appreciated. Thanks
Frank
Frank
You push in the red tabs on each side of the connector and then wiggle the connector out. It takes a fair amount of force to squeeze those red tabs all of the way.
Frankbraeside (09-20-2017)
