Have i got a lot to learn
Just read thread about installing keyless entry. Every thing is electrical, when I get frustrated I go back and work on my '63 Spyder where everything is nuts and bolts! Had my '85 Vette about 2 weeks now and I'm still trying to figure out how to replace tail light bulb and 1 burned out dash light.
I'm a little disappointed in the CD Shop Manual, it seems to tell you what you have to do but not how to do it.
My wife says I'm married to either the computer or the car,,,or both.
Oh you're in for a treat with the tail light bulb! Hopefully it's an inner one because that's easier. You have to remove the license plate, reverse light and then reach your arm in the hole to access the two 10mm screws that hold the tail light lens in place. If looking at the lens from the back of the car there's one in the bottom right corner and one in the upper left corner. Once removed the lens will come out and you can disconnect the harness and change the bulb. If it's the outer bulb then you just reach in through the inner lens hole after you remove the lens. You know, the classic reach around lol. Good luck, hope this helps.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Another is asking questions here.
Good Luck
If it's not one of these four bulbs, it will require removal and disassembly of the instrument cluster. If it's a bulb in the dic, that's different as is the light on the hush panel.
Check out Batee.com, Bryan has a lot of photo's, parts and info on his website in addition to repairing clusters if you need that done. If you need repairs, I recommend Bryan highly.
Hope that helps. Good luck.
First thing to do when you get a corvette get the shop manual.
The 85 C4 is quite simple really, the ecm will tell you what is wrong with fault codes. some things are a little more complicated without the shop manual wiring and diagnostic diagrams.
I have had my 85 for over 20 years, she is reliable and gives very little trouble. The little woman may get jealous of my car needing my time and attention at times. She calls my vette the other woman..
The dash is easy to remove and take apart, but first try replacing the bulbs without pulling the dash out.
TIP ! check battees website www.batee.com for C4 dash repair guides and tips, also i recommend replacing the factory halogen bulbs that can damage the dash with xenon or led bulbs.
I fitted a immobilizer with central locking hooked up, just lock arm activate immobiliser / unlock by pressing the button on the remote :thumbs
The shop manual will have the wiring colors for connecting the keyless entry, is quite simple when you look at just a small part of the wiring diagram in the shop manual like door door wiring diagram.
Is a pity photobucket have stopped us from posting pics recently , will see if i can get past it to post some diagrams.
For the tail lights yes they can be a pain, you need slender thin arms ... promise the little woman a nice dinner if she reaches up from under the car and pops the light globe socket out from under the car to replace the globe. I guarantee a mans arms make it tough work , will look like you have been attacked by a cat after the globe has been replaced.
Lucky for me i fitted the 91-96 bumpers, just undo two screws take the lens off and replace bulb put lens back on ...
Cheers and enjoy your C4
stabac (09-28-2017)
Just to add a lesson I seem to keep learning (or maybe cant seem to learn), be very patient and careful with the plastic interior pieces. They crack and break easily and are not cheap to replace. I seem to mess one up every time I take anything apart.
Photobucket is not needed to post pictures. Go to the little square with the mountain in it, click on it, click on Browse Your Device, and load photos directly from your computer.
