Fuel Tank Bladder?
Fuel Tank Bladder?
Simple question, I am restoring a 1990 Corvette and the first hiccup I have hit is that most of the bladder is in chunks at the bottom of the tank. Is it necessary to find a tank with a bladder in it or can I go with one of the many bare tanks?
Thanks in advance.
Thanks in advance.
It'll wash the outer layer and rust it out quickly. I looked and couldn't find one with a bladder, so I got this one.
https://www.corvetteforum.com/forums...-gas-tank.html
Happy with it so far. I found it by running the part number through amazon, as the car search failed to pull anything up.
Space387 (10-01-2017)
Thanks for the reply. I ordered a new tank pump and sender last night and opted for the bare thank like you. All things willing this shouldn't be too much of a headache, right?
What typically happens with a steel tank is that the bottom rusts out. Water is heavier than gasoline. Condensation sinks to the bottom of the tank and works its magic.
Thanks all. Last time I dealt with this was the 94 firebird formula I restored after it sat for 12 years and that was a nightmare to replace because of suspension and exhaust placement.
