What is this part?
What is this part?
When I bought my 96 Base last May this part was in the little door compartment loose. I have spent a couple of hours looking for where it goes. Those three little bumps are rubber. Anyone know what it is? Thanks,Dan
Whaleman (11-09-2017)
Thanks scrappy76 you are correct. The weird thing is there is one on the rear cover. The one on does not have the 3 little rubber plugs. Why the PO had an extra one is a question I can't answer as both are fine and not broken. Thanks again, Dan
You probably will find this amusing, but when I bought my 94, it also came with one of those pull handles in the bag from corvette central. The one that was on the cover was fine, so I just put the new one on the shelf till I need it. I could not figure it out why either.
