What works choke on a 1988 Corvette?
#41
Check fuel pressure, it should rise past 44 psi and hold when key is turned on. Is coolant temperature sensor connector round or 2 pins. If you have round connector upgrade to newer 2 pin type connector and sensor. How does it run after it starts? Check fuel pressure regular vacuum hose for gasoline.
