Tired rear spring - or is it?
Tired rear spring - or is it? Continued with another tech questions :)
Hi guys! First of all I'd like to say I'm from Finland to sorry for my English, it's not perfect but I hope you can understand what I'm trying to say.
So I bought a C4. Like in every vehicle, first thing you want to do is lower it a bit to give it more aggresive look. So I started with the rear end, as it seemed simple. So when I assemble the rear with 1.5" longer bolts, the spring is so straight that it wont touch the rubber isolators. Why is that for? Or is it normal that the isolators come loose when I jack one corner at a time up?
And if I want to lower the front, is the z51 option spring a direct fit and will it lower the car?
Mine is a 1984.
Mine is a 1984.
Finalist 2020 C4 of the Year - Unmodified
Check, are the rear hubs sitting on the bump stops? The rubber bit on the body above the hub. If so, that's bad, you're way too low.
Have a pic we can see?
I bought just the bolts and nuts.
The problem is not that I'm hitting bump stops - I haven't adjusted it that low, the problem is if I fit the new bolts, they are so long, that my spring is loose.
Also I had bushings between the hub and spring, has someone added those or should I have them?
The way it was:
https://ardhu.kuvat.fi/kuvat/Corvett...pg?img=smaller
And how I assembled it:
The way it was:
No they are not hitting bump stops, The problem is that when I jack the car up, the rear spring comes loose from the bolts that adjust the ride height. Should they? Or should they stay in contact with the isolators in the bolts. I cant upload a picture for some reason...
If the spring applies no tension when jacked up, that says two things to me. Either your rear shocks are too long compared stock, so the rear hubs sink much farther down than typical. Or, something is wrong with your spring, either it's cracked or mounted incorrectly.
I could be wrong, I haven't tried lowering my Lady yet.
Hmm, checked your pics, that spring seems awfully thick. Maybe the spring was changed to a super stiff to allow for really low rear. In that case, it wouldn't travel much and the loose bolts would make sense.
Here's how my spring looks on jacks.
FYI, you have to have so many posts before you can paste images.
Hmm... Searching rockauto, the shocks should be about 14” long extended lenght? Need to measure that, thanks for advice!
should there be bushings between the hub and spring? Looking throught internet, my rear end looks odd
Your first snapshot "HOW IT WAS" is what I'd expect for an '84 or '85 except for the washer stack at the nut and I believe it's missing a bushing likely on top of the spring so the washer stack was used to fit it.
In this image look at 42, 44 and 46
Maybe a previous owner removed the one bushing to let the spacer drop to the lower bushing through the spring in an attempt to lower it. I've no idea!
I don't have a 'hands on' to an early rear spring so I can't tell you where to look on it for code.
Is there maybe a SPID/RPO label in the rear storage compartment? It might be interesting to see the suspension options.
I can tell you the rpo codes when I get to the car So it seems that there's nothing wrong with my rear leaf? If I wanna lower this thing, I put on new bushings like it was (both sides of the hub and spring, right?) and then make a new steel bushings(number 46 on your photo) that is equally longer to the bolt that I have already bought? Correct me please if I'm wrong cause this is how I see this thing now
Can't tell you that - only a close inspection answers that question. Early cars (no personal experience) I don't believe respond to the longer bolt lowering procedure.
I don't get the 'he!! bent on lowering'
Have you bought new bushings? How many?
This is no different than a car with conventional coil spring that are lower and stiffer than stock: sometimes they can get loose in the spring perches when the suspension is at full droop. Anyway, don't worry about it. As long as the spring ends are contacting the isolators when the car is at normal ride height (i.e., it isn't resting on the bump stops), you're in good shape.
PS - What WVZR-1 wrote about the missing rubber bushing and metal sleeve:
The OP's configuration I believe hints a FE7 build '84 & '85 only and not present on base build, also '86 and later didn't use 4 cushion & spacer configurations.
Ideally I believe you put the car back to it's original configuration and move forward. Modified by a PO I'd say for sure. Why and for what purpose? Who knows.
The OP could maybe check the other side to confirm both sides are the same. OP needs to ID the rear spring in the car also I'd think.
The sleeve/spacer isn't missing in the OP's car, if the sleeve/spacer were missing there would be "nothing" to keep the bushing snug to the suspension support/knuckle. The "washer stack" hints that maybe the bushing above the spring is missing but there ain't no snapshot confirming.
Again, my car is the same way. And I believe any lowered C4 would be the same, unless someone goes through the trouble to make a new sleeve from tubing or pipe stock. And if you do that, then it won't have adjustable ride height - just a fixed lower ride height. You wouldn't be able to make adjustments for cornering weighting or other needs. I don't see any reason that there has to be a sleeve and either of the two inside bushings. Again, as long as there is any load on that tire, there will be tension on the bolt.
The spring is BMH 004588. The RPO wasn't in the center glove box or rear boxes.
The rear shocks were 14" extended like they should.
I assembled the car with longer bolts, all is good! Ride height went down like I have hoped and there is still room between hub and bump stop.
Now it's just me to decide do I want to make a new metal bushings between hub and spring... And then I need to bought a set of bushings to those bolts
Thanks everybody very much for the help, you all have been really helpful!
Okay so the rear end is sorted, and I'm happy for it. So it's now time to move to front end, right?
If I want to lower it, lets say an inch... I came across ZR1 front spring, that is relatively cheap. Would it lower my car, since it has the FE7 suspension according to you guys? Would I need to change the center hanger type things?
Or do I just buy the lowering hangers and then slice the majority of the rubber bushing away from the original front spring?
Where do I need to post my VIN code to get the RPO list? I have understood that some corvette club(?) offers that?
Thanks again
Thanks again
You need '87 or earlier for a 'fit' - if the spring you've found is a ZR-1 it's a later suspension configuration.
Since you have an '84 missing the SPID label it would be interesting to look near the 'right side' hood latch and see if your car has the earlier riveted TRIM TAG. It won't have a RPO list but limited information.
