Lets talk spoilers
#42
Got it from member named redrock.
Gregg, car looks great. If you could lower the rear about an inch or so, it would be perfect.
Doesn't hit too much harder with the bigger wheels. When I switched to 18s/19s, I put them on at the same time I lowered the whole car. It does make a huge difference in the ride. Turns corners like it's on rails. (It does scrape bottom sometimes) Your side-pipes might restrict going any lower. Do those bottom out very much?
AFTER:[/B][/U] Bumpers off a 1995 with hood, pipes, and wing. (Also 2-tone interior and 383 stroker). Like the post above said....Go big or go home!
Note: Wing is the general shape of the Impala wing near the top.
At one point, I considered newer, larger diameter wheels too. Ended up being a bit concerned the car would "hit" harder...as have my other cars when going to larger wheels with lower profile tires. How did that work for you guys on the vette?
18's and 19's....????
#43
I was going to remove mine when I purchased it years ago. Got used to it. Now I love it. GM option so it is staying and I get many compliments on it.
