Help locating a specific low profile rear wing spoiler
Yep, you are wrong. The reason it looks like that, is that some of the early C4 design sketches had a low profile rear wing. It didn't make it past the early design stages however, but one very similar did make it's way onto the 1982 Firebird, ala Knightrider as a factory option.
Thanks! Yes, I think yours was marketed by GM, but Chevy never had an option for a factory spoiler on the C4. What I believe yours is however is a dealer installed GM accessory that was carried in the GM parts catalogs back in the day. They problem is I cannot find any GM advertising documentation that it even existed as a GM accessory, let alone find someone that still has them available. If you find any hidden markings on the bottom side, on the pedestals, or anything to help me identify the manufacturer of your spoiler, please let me know. So far you are the only active member on the forum that even still seems to have one. Your car is beautiful by the way! I thank you for replying and all the help thus far!
Merry Christmas!!
Merry Christmas!!
CRAIGVETTE (12-24-2017)
Thanks, that sure looks like it from that angle! I have seen it with and without the embossed CORVETTE. I also remember that the pedestals were lined up between the tailights, do you have a photo from straight on from the back, and other angles like in my original post? Most importantly, do you have any details about who makes it and where to still find one? Thanks again!
Merry Christmas!!
Merry Christmas!!
Hope this helps. There are no markings visable. I saw one other vette with this wing. If I find any more info I will get it to you. Merry Christmas
these people offer 3 that they don't show images of. They sell ACI and usually ID stuff that is ACI. You might try them for snapshots. The one that is actually pictured is maybe close to the GMPP one.
http://corvettespecialty.com/corvett...r-wing-1984-90
I've a friend that bought a complete package for an F-body that was a GMPP offering. What you might need is a GMPP PP-4 catalog from 1992. I thought I had one. I actually might but just having a tough time putting hands on it
There would be PP-3, PP-2 and I believe PP-1 prior but don't know if there was any ground-effect packages.
Thank you very much! I have no doubt that yours in the GM accessory spoiler made for the C4, and probably installed by the dealer. It is just what I am looking for, so hopefully I will be able to find one eventually. Thanks again for all your help, and Merry Christmas!!!
I believe you are correct about the GM catalog, I just need to be able to find one that far back, and then find a GM dealer that still has a new old stock available. Easy right, ha, ha. Thanks and Merry Christmas!!!
The posts do come between the tail lights. I do believe it was designed for the corvette. The spacing and all the alignment is correct. I did see a pontiac spoiler very simular if not exact. I will look for markings or numbers and send a better pic. Thank you for the compliment. It all original paint also. Runs great.
kenmohr (12-25-2017)
That looks like it or close. Worth looking into. I will take a betterlook under mine to see how they line up with the seams and recess.
CRAIGVETTE (12-25-2017)
AFAIK, fiberglass manufacturers have all been mentioned in this thread. (Ecklers might have been left out but they don't make this style wing that I see.) Toledo Pro sold out to ACI...and Vanacorvette went out of business. There was another ("49th Street" IIRC) that also went out of business years ago. I'm not even sure Greenwood is still in business? It seems likely/possible that an "accessory" wing would have been made from one of the aftermarket companies way back when.
For some reason, I seem to remember that wing being in either CC or MidAm Corvette mags 10yrs ago.
#33
We looked at a pontiac wing several years ago. If I remember it was slightly different but we had to look close to pick up un it.
#34
I'm not so sure the "Designer Low Profile" wing is tall enough to cut down. Sounds like you think the legs are taller...like ACI's "Collector Series Wing". I think it's very similar to the one pictured in the OP though shorter (front-to-back) as seen in the top-down view.
Back when all the catalogs carried a plethora of spoilers for the C4, the one in the OP was the one I was interested in, as it was always the lowest of the low profile wings.
Doesn't sound like it is manufactured any longer, so maybe someone will see this post and know of one in a Corvette salvage yard or seen one on a wreaked C4.
#35
Would you be so kind as to measure the height of your pedestals so I know how high your wings sits above the rear facia? Then I would at least be able to determine how much I would need to sand off of the ACI pedestals to make it the same height as yours. Thanks!
#37
Pro Mechanic
I thought it was an Early 3rd Gen spoiler too -I used to have two early 3rd Gen's. But I think the "feet" on the 3rd gen spoiler are a lot longer, front-rear, and the leading edges are more sharply pointed...than that white one pictured above.
#39
not sure which one now. Was one of these I believe, V73, 731, 739, 1ay, 1sb.
#40
https://www.corvsport.com/1989-c4-corvette/
http://www.corvette-web-central.com/C4RPOcodes.html
