88 help with intermittent hard start
I'm looking for a corvette tech in the Huntington Beach, Ca. area that can help me with this intermittent hard start. I've replaced the fuel pump,fuel filter,injectors from FIC. Also plugs, ignition coil, wires, dist cap and rotor. I still have this intermittent hard start and when this happens it becomes flooded. I took it to a shop here in HB and after charging me $180 bucks they said it was the injectors. So I replaced the injectors and still have the same problem. Pissed that $180 away along with the price of injectors. I really need some help from someone that actually knows something about corvettes. I will pay for someone to help me with this problem but I'm retired and can't just keep throwing parts at this thing and paying for someone that doesn't know what the hell they are talking about. Hoping someone can really help me out here.
Question does it just keep turning over but not fire up and run? Also does it still have the factory vats security because if yes on both it may be the security.i have this issue and believe the vat resistor in my key is too low in resistance as I've measured it.sometimes my Vette will start wright up and others it turns till battery is dead.ive ordered a new key and am hoping that's the problem.otherwise it could be the wires from ignition switch for the vats as there notirious for breaking as they get older.i don't know if this is your issue if yes I hope it helps a little.
jameskarate (02-19-2018)
