L98 Injectors replaced -now 4000rpm Idle
1990 C4 Coupe L98 bought new,now 43K miles : Having STD easy mods, Chip, K&N, Stainless Headers, TB air foil, stainless exhaust.
I replaced the old injectors with ACC-180830 from Summit. Double checked everything then started it up. It started quickly BUT was idling at 4000 rpm (yup 4K not 400). I shut it down and tried 3 more times but same problem. I will be checking the SES indicator and note any codes later today. I am trying to get a jump on the problem by posting this now.
I have searched the forum's for some idea as to the problem:
1) could be a vaccum leak. Hose or connector open. Is this probable?
2) IAC - malfunctioning or not connected properly. Some indication in some posts the IAC solenoid can stick when laying plenum down? Can the IAC cause extremely high idle?
3) Life hates me - naw...
If anyone has seen this type of problem, I'd appreciate the input.
Jerry
Jerry
Iac malfunction will not cause that idle. Sounds like a huge vacuum leak. Did you plug in the large vacuum hose that goes to the brake booster?
Got a link to that injector? What size is it?
Not that high.
Virgin sacrifice might help?
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
So pull the chip and make sure the airfoil isn't causing the TB plate to hang open.
And this time look for any hoses or connections that may be loose or cracked from handling.
Good Luck
Sounds like the throttle plate is hung open.
Either that or there's a huge vacuum leak. Even the brake booster hose will only run the idle up to 2500 RPM or maybe 3K on most engines. Listen for the huge sucking sound.
And get that STD checked out and treated.
Thx for the reply. From the reply's it sounds like a vaccum leak. All the other parts were on the car for 10 years - only changed out injectors and this is result. I will break it down and double check everything looking for that leak.
Thx for reply. Vacuum leak seems the consensus Thought I assembled it fine, but seems I missed something. BTW, The STD is fine, but my AIDS is flaring up now......
I'd sell the chip and the air foil on Craigslist or Ebay. List it as a high performance mod and someone will help you recoup your money. Not sure about the headers and if they are shorty headers, probably not worth much gain.
Not that high.
Not that high.
But hey, if your interested, these are my headers,lol
https://www.lmperformance.com/69612/...nd-y-pipe.html
Dude, I think its puff puff PASS time. I'm not selling anything, I was looking for support....
Yes, they are better than shorty headers since you don't have to worry about CA emissions and can use them. Next thing is to dump the intake after you fix the issue and then get a dyno tune. Assuming your injectors are same as what you took out. I would get a scanner that can read your ECM and not the code reader which is a glorified paper clip.
PS. I did ask you about the injectors since I wasn't sure whether those were the right size which could give you issues if they are larger than stock and the ECM doesn't know that. Ask me how I know. BTW, ACC-180830 doesn't come up on Google or Summit hence the question. Please continue being huffy and I'll go puffy.
https://www.summitracing.com/parts/a...EaAqDeEALw_wcB
If so, here are the specs below. I can see why there may a problem.
Brand:Accel
Manufacturer's Part Number:150830
Part Type:Fuel Injectors
Product Line:ACCEL Fuel Injectors
Summit Racing Part Number:ACC-150830
UPC:743047800362
Injector Advertised Flow Rate (lbs/hr): 30 lbs./hr.
Injector Advertised Flow Rate (cc/min): 309.0cc/min
Injector Impedance: 14.4 ohms
Driver Type: 12V saturated circuit
Overall Height (in): 2.880 in.
Seat to Seat Height (in): 2.270 in.
Manifold O-Ring Outside Diameter (in): 0.573 in.
Fuel Rail O-Ring Outside Diameter (in): 0.574 in.
Outside Diameter (in): 0.943 in.
Injector Plug Style: Jetronic/Minitimer
Wiring Harness Included: No
O-Rings Included: Yes
Quantity: Sold as a set of 8.
In-Store Pickup:Choose In-store pick-up (OH, NV, GA, TX) on our web site.
UPC:743047800362
Like ^^he said. Can't just install a set of 30% bigger injectors without tuning for the change.
Oh wait. You mean ACC-150830
I don't think your car came with 30pph. If I follow the sequence of events, your car has the mods and was working fine. You change to the larger injectors and neglected to mention it to the ECM and it ASSUMES it is 22pph so it is giving the same pulse width it was but you are dumping more fuel. A larger injector dumps more fuel than a smaller one at the same pulse width
I had fuel dumping into the right side because the left bank shorted out the fuse.. No signal, no pulse. O2 was on the left so it reported that it was very lean and the ECM dumped fuel on the right so rpm went up and headers glowed on that side.
