'94 with AC issues
BLUDICE (04-25-2018)
Assuming C68.. Have you done an A/C reset? disconnect battery for 30s.. reconnect, turn key to on (don't start) wait for the Blend door to self calibrate, then start, check to see if blows cold and Compressor kicks on
In auto mode (recirculated) 60 deg, it should not cycle much if at all. If it is just on for 2seconds you are low on refrigerant
Manual a/c or C68. Blend door motor stuck? Remove the 3 7mm screws with hood open and have assistant move a/c from 60 to 90 and verify you see the blend door move. If not you must can spray some wd40 or similar in the entire area with the movable door and wait a few hours. You can gently try to pry it waiting doesnt work. After that , could be actual blend door motor or heater box. With motor /ignition off you can gently move the motor by hand. See you FSM if needed
BLUDICE (05-01-2018)
I had similar symptoms and it turned out to be two hose that were leaking pretty bad.
+1 A set of gauges would come in handy here. Low refrigerant charge or a restriction in the circuit can cause short cycling.
BLUDICE (05-04-2018)
