manually opening headlight doors
Old 04-29-2018, 01:04 AM
quantum93blue
Junior Member
Default manually opening headlight doors
When my headlights don't open with the headlight switch, I found if I loosen the manual ****, turn the headlights off then back on again they open. Can the manual **** keep them from opening if the **** appears tighter as opposed to turning more freely?
quantum93blue is offline
Old 04-29-2018, 02:31 AM
xrav22
CF Senior Member
xrav22's Avatar
Try cleaning the terminals with electrical contact cleaner, sometimes it heps provide the extra voltage to operate the headlights.
xrav22 is offline
Old 04-29-2018, 12:31 PM
PLRX
Semper Fidelis 1988-2011
PLRX's Avatar
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I had that problem in the past and there were the crumbled bushings inside the gear mechanism.
Like he said, clean all connections first and good luck.
PLRX is offline
Old 04-29-2018, 07:51 PM
aklim
CF Senior Member
aklim's Avatar
Can you see if the motor is even getting the signal? If not, the module may be at fault.
aklim is online now
Old 04-29-2018, 11:10 PM
gdl2165
CF Senior Member
When you use the switch and they don't flip open, do you hear the motor running for a few seconds anyway? If no then I'd agree it may be the electrical connection. If you do hear the motors trying to run then my bet would be on the gears and/or pellets inside being trashed. In that case rebuild the headlight activation mechanism. It may be you have a gear with some worn teeth and using the manual **** a little bit moves it just enough to get it to a slightly better set of teeth.
gdl2165 is offline
Quick Reply: manually opening headlight doors
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
