1992 stock Bose radio bad reception
So my 92 has had terrible radio reception since I bought it about a year ago, think I finally want to tackle the problem. The previous owner had the antenna replaced(it rises and retracts normal) and speakers rebuilt. The reception is so bad you can't really listen to the radio, but fluctuates as you drive and sometimes for a few seconds becomes normal. Any ideas where the issue may be?
Also anyone know a good place to get the original head unit rebuilt for a good price?
Any suggestions are highly appreciated!
DriveV8Faster (05-08-2018)
If you knew that you had a good coax lead, the antenna was replaced with other than OE and the 4 'ground plane' leads were removed I'd think you would get 'none/very little' or very weak reception. You need to first confirm that the ground strap to the frame is secure after maybe cleaning the ring terminal and also the chassis component. The 4 ground plane wires are same length as the antenna mast (31 1/2").
I don't believe the 1st move would be a 'radio service'.
