C4 suspension
C4 suspension
Want opinions. Have a C4 Sport with adjustable FX3 suspension. Cant really see spending a grand plus to get it back correct when standard shocks seem perfectly fine. Car has 80K and used just for casual sunny day rides. If so what shocks are recommended. Not going to be tracked. Just sunny joy rides.
Would you spend a grand on tires ???
shocks
I have other cars worth more that I do more with that I would gladly put that money in. The C4s are only 8-10K cars and just can't yet justify that when a good casual ride is available for a fraction. I also worry about digital dash issues and constantly battle my push button climate controls.
I assume these cars will some day appreciate when enough of them have been thrashed or left to die but they made enough of them to make me wonder if that will happen while I might still drive this one.
Appreciate the input. Truly haven't decided yet.
I'm still wondering why CR would say "would you spend $1K on tires"
On the cheap end, many people recommend KYB shocks for a C4. I guess they're okay. They are cheap. For street driving, I have been very impressed with Koni Sports (yellow), which are adjustable for rebound and can give a very good ride quality while providing good control. Those are still twin-tube shocks, but they have good valving and a lifetime warranty. Very possible a better shock that is actually cheaper (~$700/set) are the Ridetech HQ dampers, which are also adjustable for rebound. They are monotubes (more desirable) that use Fox internals, and also effectively have a lifetime warranty.
ETA: As grandspt notes below, the adjustment ***** on the Ridetechs are really easy to access, unlike the Koni rears which must be removed to adjust them.
I just installed the Ridetech HQ adjustable shocks and I am extremely happy with them. It cured a problem with my rear suspension that I have been trying to chase down for over two years.
The adjustability works great, smooth ride or firm ride only a few clicks away and easy to access the adjustment ****.
No track time, okay. But you drive a true sports car. Even with "spirited" driving the FX3 is superior. If only from a safety perspective.
Comparing FX3 to standard shocks is not really fair. They're worlds apart in performance. If I can find the video comparison, I'll post a link. FX3 is astonishing.
You're considering an amputation over a cast, IMO.
Then again, my 'vette is NOT an investment. It gets driven daily and often goes for a spirited drive in the mountains. Like last week at the Tail of the Dragon.
With the FX3 system, you need to find out what trouble codes are in the computer so you can start to figure out just how much money it will cost to bring the system back to working order. IIRC, there are 34 possible error codes for the Selective Ride Control system.
Bilstein had been able to repair the shocks but from what has been mentioned here, they no longer have parts for the rear shocks. The actuators are available but they are pricey. There is a guy who can rebuild the actuators.
Given the potential of paying 4 figures for getting the FX3 system back in operation, it may make sense to just go witth something like Bilstein Sport shocks or even the Z51 Bilstein shocks. FX3 was a good system when it came out. Bilstein had worked with Ferrari to build an adjustable shock system and by 1989, Bilstein adapted that Ferrari system for the Corvette. At the time, it was a very good system.
