Antenna not coming up
Start with checking at the antenna motor to be sure you are getting power. If yes, check ground connection. If ground is also good its likely the antenna needs R&R.
Cruise-In II Veteran
My antenna is not coming up..any ideas?
If so, does it retract when radio off?
Good news, if you need to replace it's pretty easy (compared with my damn '88) and some good vids on how-to for '95 & '96.
