Baby needs new shoes. And new feet...
I've been kicking this can down the road for a lot longer than I should have, and it's time to get off the dime and get it done. My '94 ragtop car has been wearing a set of chrome, reproduction C5 thinspokes for at least 15 years. I've loved the look of them, but they've always had some "issues," and the tires are overdue for a one-way ticket to the scrap heap.
I'm looking for a fresh set of wheels that are as close as possible to what's on there now, which I believe to be 17x9.5 front and 18x10.5 rear. I see that OE Wheels offers a similar wheel in 17x8.5 and 18x9.5, which seems to be the only two sizes they offer in this style of wheel. I don't want the deep-dish option.
The questions I have are:
Who's running 17x8.5 and 18x9.5 wheel sets on their late-C4? Are you happy with this staggered size combination? Any problems, clearance issues, etc?
Whose tires are you running on them, what sizes did you choose, and are you happy with them?
Is there a vendor that's offering these same wheels in different sizes?
TIA for any feedback.
Live well,
SJW
Live well,
SJW
I'm not putting new wheels on, but I am going to get the wheels refinished on my '89, and I'm going with Firestone Firehawk Indy 500s, for new tires in a 275/40-17 all around.
I've been researching tires for the last month, and the new Firestones seem to be the ticket. That and they aren't that expensive either, $130ish per tire, and the do have a rebate going on right now.
Just look around, you will find something.
D.
D.
Why do you want to stagger the width and diameters? There's no need for that for fitment or performance reasons. You could go with 18x9.5 at all four corners with proper offset (56mm), and 275/35r18 tires all around. If you just want that front 17x8.5 for a particular look (which is all opinion, of course), then you'd want to match that rear tire size with 245/45/r17 tires up front. You could also run 9.5 in front and 11 in back, or 11 at all four corners.
If you decide to run 18s at both ends, you might consider the Forgestar CF5. You could get their "semi-concave" in 18x9.5. Any wider and you'd be into their "concave" design, which may not appeal to you if you don't like "deep dish" looks. Mine are 18x11 at all four corners and so "concave" design, but this will give you an idea of how those wheels look on a late C4:
They are Gunmetal finish, yes. I like the look, but silver would be great also. You're gonna like the way they look.
I'm running firestone indy 500s as well. So far i have about 10k miles on them. They are really good tires! Great grip and they tread water very well!
Connor Coughlin
Connor Coughlin
I forgot to mention tires. I have BFG Rival S tires on those Forgestars, but you don't want those for street tires. On my sawblades, I have a new set of Riken Raptor A/S tires that I bought from Tire Rack. They are grippy and decent-riding tires, but the best thing about them is the price. I think they're up to ~$80ea for 275s either in the 17" or 18" wheel size. I recommend them as a budget-friendly, high-performance tire.
D.
D.
Live well,
SJW
I guess the main motivation to go with staggered widths is that the factory sent them out the door with staggered sets. Primarily, if I understand correctly, to reduce tramlining. Staggering the diameters isn't important to me. What are important to me are the following:
1. Road behavior, including noise (quieter = better), minimzing tramlining, and traction (chiefly dry traction as this car isn't often driven in sloppy weather).
2. Diameter match to OEM (for speedometer accuracy), which I believe was 26.0" for the rear 285/40-17 tires.
3. Decent tread life.
My preference would be another set of Michelin Pilot Sports, but I don't think I can get them in sizes that would suit.
Live well,
SJW
Thanks for the reply.
I agree the 8.5" fronts were a response to complaints of tramlining. If you want to replicate that, by all means do so. But I still recommend sticking with 25.6" (245-width) tires, partially for looks and mostly for better tire selection. Tire Rack shows five different Michelin Pilot Sports in 245/45/17, and even more in 245/40/18. So the 25.6" diameter tire in either wheel diameter is by far your best option. Match it to a 275/40/17 or 275/35/18 on a 9.5" wheel in back.
Nice looking car you have there. I like those wheels, but I like the look of these and it's what I'm essentially hoping to replicate:
Live well,
SJW
Live well,
SJW
Would look a lot better lowered a bit IMO. All that fender gap!!
All the C4s in later years that came with the Z07 or Z51 suspension packages came with 17x9.5 wheels at all four corners, with 275/40/17 tires. Those are 25.6" diameter. Also, the ZR1 and GS came with 25.6"-diameter tires. I doubt the factory changed the speedometer calibration between the two different tire diameters. It's very minimal. My 96 came with the taller 255 and 285 tires, and the speedo is within 1-2mph of accuracy with 25.6" tires. So speedo accuracy isn't an issue: with either size, it's correct within GM's margin of error.
What would be the ideal wheel widths for the tire sizes you suggested here?
Many thanks in advance!
Live well,
SJW
The gap is actually slightly smaller than it was with the factory wheels and tires on the car.
Having said that, I'll agree that it would look even better with less gap, but lowering this car is strictly out of the question. My driveway approaches the garage floor's concrete slab on such a steep incline that the X-brace under the car high-center-scrapes while crossing the edge of the garage slab when the tank is full, at the car's current ride height. Any lower, and things would get really ugly.
Live well,
SJW
Live well,
SJW
To clear things up tramlining is?
Is that the effect of following the trenches in the road set by wear and heavy vehicles? If so I never new there was a name for it. For what its worth I just put a new set of indy 500's on my car, 275-40/17 all 4 corners and I have less an issue with the ruts than my Firebird on 245-54/16 tires.
I have no idea how much it might show up with square tire sizes compared to staggered widths, as my C4s have always worn staggered-width tires. But, I'd prefer to not see an increase.
Live well,
SJW
In the past (tire technology is changing A LOT though)
Staggered = Performance
Square = Gives the car a more planted feel
Now, advanced drivers will use a square and large set up on their cars for serious grip and handling.
IMO if you want it to feel like a cruiser put the 8.5's on.
275's - 315+ in front will have more contact patch and you will have to react to that contact area.
This might explain it better
https://www.tirebuyer.com/education/...e-wheel-setups
SJW (06-08-2018)
Sorry for the delay. I was out for work training until this evening.
245 tires fit well on 8.5" wheels, and 275s fit well on 9.5" wheels. Those are the widths Chevy used on various C4s, both with 56mm offset. Stay close to that (maybe 50mm for a slightly more aggressive/wide look while staying well inside the fenders) and you'll be good shape.
SJW (06-08-2018)
Thanks for the great advice, and the link to the article, guys. I've been swamped this week, so haven't had a chance to wrap this up yet, but I'll get on it shortly.
Live well,
SJW
Live well,
SJW
