89 Won't Idle - Should I buy as is?
Old 06-10-2018, 08:12 PM
woodcrest
woodcrest's Avatar
Default 89 Won't Idle - Should I buy as is?
I am looking at an 89 that has been sitting probably a couple of years.
Engine starts, but won't idle, engine stops when foot taken off pedal.
May buy as is.
Where should I look first?
Take a chance?
Old 06-10-2018, 09:35 PM
playsdixie
playsdixie's Avatar
You didn't say how much....issues you stated could be overcome with a tune-up and idle adjustment...how ever, wouldn't hurt to have someone who knows L98's look at it....can be lots of work restoring her to her original condition.....older c4's are 4-5 grand, a little more for newer years....
Old 06-10-2018, 09:44 PM
woodcrest
woodcrest's Avatar
Buying for 4500, perhaps 4000, essentially from original owner, 2nd owner did not do much with it, also all 4 tires look new, new battery, 110,000 miles
Old 06-10-2018, 09:45 PM
woodcrest
woodcrest's Avatar
also it is a convertible with 6 speed manual (ideal combination for good resale?)
Old 06-10-2018, 09:57 PM
Kevova
Kevova's Avatar
If you have the ability and means to fix up car yourself, it maybe a ok deal. If you're having to pay maybe not.
Old 06-10-2018, 10:32 PM
aklim
aklim's Avatar
Received 2,225 Likes on 1,939 Posts
Have you considered getting a Pre Delivery Inspection done at some dealership that knows C4 Corvettes and has the right tools to test everything like a Tech 1 scanner? Maybe a Tech 2 can also work? I haven't tried it yet. A PDI will give you an indication of what is wrong and you can ask how much it will take to make it right. That will aid you in the decision of what to offer.
Old 06-10-2018, 11:04 PM
jv9999
jv9999's Avatar
If it has two year old gas in it, it definitely won't run well.
Old 06-11-2018, 01:35 AM
AgentEran
AgentEran's Avatar
For 4500 you can get one that runs
Old 06-11-2018, 07:29 AM
Paul Workman
Paul Workman's Avatar
$4500 LESS what it takes to fix whatever turns up.
Old 06-11-2018, 07:56 AM
playsdixie
playsdixie's Avatar
Just maintaining a c 4 can be expensive..unless you're mechanically minded and have tools, better to start with one that runs....or give him 2500 break out the sweat...
Old 06-11-2018, 03:28 PM
CVG323
CVG323's Avatar
looks like you purchased it.
did you get it to run good?
Old 06-12-2018, 02:26 AM
woodcrest
woodcrest's Avatar
OK, idles now, owner replaced air cleaner, changed oil and filter,,,,,but now billows of smoke....but mobile mechanic says its the bad gas, not a oil burner....maybe a bit through the valve stems, but that should clear.
Two questions.....ok...three
1. Is the smoke bad gas in your opinion? (smells like bad gas)
2. What does it take to drop the gas tank? (should be drained, not just refilled?)
3. Far price, noting the risk I am taking? seems to be a solid car in all other aspects...yes?
See attachments
File Type: avi
File Type: avi
Old 06-12-2018, 08:41 AM
hcbph
hcbph's Avatar
Never pulled a tank but looks to be a bear because of having to remove the rear bumper. Looks easier to remove the filler and siphon the tank dry.
Old 06-12-2018, 08:48 AM
Paul Workman
See attachments
"Bad gas", my ***! I've run cars that have sat outside w/o running for 7 years and the fired up and ran and idles OK as long as water hadn't condensed in the tank. So, I declare on the "bad gas" explanation.
There are a host of reasons why there might be a gasoline smell having nothing to do with the smoke (water vapor), e.g., water condensation collected in the exhaust (will disappear in 5 min or so), head gasket leak, to name a couple.
Oil smoke is blueish and is slow to dissipate. Gas (running very rich) is black. Water (antifreeze) is whitish and dissipates quickly in the air - unlike real smoke (e.g., oil or gasoline smoke).
And, how did the idle get "fixed"? Did someone twist the idle air screw and call it good?
I'm not trying to be painting a dark picture, but I've fussed with cars since I was a teen, and now am nearly 70. Tho I'm not too old to learn new stuff, but "BAD GAS" is often a catch-all for something else more serious (and the salesman doesn't want to admit to it, or consider it).
If you already bought it, at the very least I'd be inspecting the spark plugs. Are they gasoline or oil fouled, or are one/some "steam cleaned" (as in water/coolant).
Can you or someone handy scan it for codes? (That would be interesting to see...)
Old 06-12-2018, 11:51 AM
woodcrest
woodcrest's Avatar
The gas gage is on reserve, maybe simply run it until the tank is empty?
Old 06-12-2018, 12:53 PM
84 4+3's Avatar
Received 1,373 Likes on 1,061 Posts
If yours is like mine, reserve means get gas now because you're about to run out stupid. I had my reserve come on in my driveway... 3 miles to the nearest gas station and she was bucking pulling into it...
Old 06-12-2018, 01:26 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
What is fuel pressure cold/hot?
You could check cylinder compression values and leak down rates.
My prior '88 had 90k miles on the clock and rather low fuel pressure. The oil would get dark before an oil change.
The current '88 with ~50k miles runs ~40-45lbs idle oil pressure and 50-60lbs on highway, with clean oil at change time.
To 89 Won't Idle - Should I buy as is?
Old 06-12-2018, 03:39 PM
woodcrest
woodcrest's Avatar
From what I know water in the engine is almost (exclusively?) always due to overheating. The owner said they parked it an it sat. It did pass smog back in December of last year. CAn an engine get water in it from just sitting? Thanks. I am think of offering half what they are asking...2500....but then again if someone else buys it, I will not lose any sleep.
CVG323
CVG323's Avatar
sent you a PM.
Old 06-12-2018, 03:50 PM
woodcrest
woodcrest's Avatar
Oh, also, it started to idle properly without any adjustments...just had to have a bit of time running...
Quick Reply: 89 Won't Idle - Should I buy as is?
