Build Sheet/RPO Questions 1984 C4
Just recently purchased a 1984 C4. When I looked up the RPO codes on the sticker it listed the color as 63L 63U with the two tone paint option. Both of those colors are light bronze. The RPO list I was using for the 1984 Corvettes did not list 66M as a paint color option, but on my sticker there is a 66M which is dark bronze. The car is two tone, light bronze over dark bronze. Just wondering if it is normal for there to be discrepancies with the codes? If I am reading the build sheet correctly it was built in June of 1984, so it was an early model.
Any help is appreciated.
June 84 is a late model 84 iirc. Mine has a build in late 83.
If you see a two tone bronze option then that would be correct. A lot of rpos are changed year to year so if you can't find it I wouldn't be worried.
