Too many issues
Too many issues
So my father and I have replaced the distributor in my 1994 Corvette (thank you everyone that helped with that) and now the engine is running crazy hot, 270 to 300 degrees hot. Quite literally immediately after replacing the distributor. We checked the codes and by the Haynes manual it says that our distributor is still causing issues, that our "coolant sensor circuit" needed to be checked and replaced, and that the "right bank oxygen sensor circuit" must also be checked and replaced. All these issues emerging now seems to me a bit suspicious. What are your thoughts on this? Has anyone else experienced similar issues? Both me and my father are new to Corvettes, and we would really appreciate the help
Thank you everyone,
Brody Paulk
Thank you everyone,
Brody Paulk
scrsinc (09-29-2018)
Received 6,943 Likes
2015 C2 of Year Finalist
when installing the water pump did you forget to put the drive gear back in place
Finalist 2020 C4 of the Year - Unmodified
-- Guy who learned the hard way
IMPORTANT: Start this with a cold engine, not anywhere near warm. On a hot engine, taking the radiator cap off will spew coolant all over, in a hotter-than-boiling state and burn you. Make it a habit to check the radiator hose before looking at the cap!
