Repairing 88 door skin
Old 10-06-2018, 09:56 AM
Matt81
Matt81's Avatar
Default Repairing 88 door skin
Anyone have a good solution for the top of the door panel skin peeling away? I have some 3M 90 spray adhesive, but I'm not sure how to get the top edge relaxed enough to let it bend.
Soften with a heat gun? Use a stapler?
Here is the driver side of the 35th Anniversary I'm resurrecting.
Driver Side, peeling door skin
Old 10-06-2018, 10:00 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
Wow, that is a lot of "warpage". Is there anything behind that "skin" or is that the entire outer shell of the door?
Old 10-06-2018, 10:19 PM
Matt81
Matt81's Avatar
The door panel is ok, just the vinyl (?) Is curled over.
Old 10-07-2018, 04:36 AM
ls777z
ls777z's Avatar
There is no fixing that. You would be better off replacing the door, which in the long run would probably be cheaper than replacing just the door skin.
Old 10-07-2018, 08:15 PM
HAD2HAV2
HAD2HAV2's Avatar
88 door skin bought new in 2003 and because the white aged and yellowed after 15 years, I repainted it recently and added new carpet.
Old 10-07-2018, 08:25 PM
Matt81
Matt81's Avatar
Nice job! Mine is a long ways from looking that good. I'm working on getting some studs mounted into the top cap as all but one of the studs are broken off. Someone also used something resembling gorilla glue to attach the carpet, with some nice blue showing on the door panel.
What did you use for painting? Looking for anything I can to pretty up this Anniversary Edition!
Old 10-07-2018, 09:33 PM
65Z01
65Z01's Avatar
Oops, my bad. Didn't realize that was the inside...
If you clamp a straight, stiff rail to it will it straighten and lay smoothly? If so there are some epoxy adhesives that should hold it nicely.
Old 10-07-2018, 09:56 PM
Matt81
Matt81's Avatar
I have a section of aluminum channel I'm thinking of using. Clamp it down after spraying with adhesive. Aluminum stock is for the electric can I plan on putting on the 78 when I swap it from TBI to TPI.
I'm wondering if hitting with some heat might relax some of the curl before attempting to glue? the adhesive would be fighting that bend.
Old 10-07-2018, 11:59 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
The door skin is the fiberglass layer on the outside of the door. A door panel is the vinyl covered object on the inside of the door.
Old 10-08-2018, 07:17 AM
Matt81
Matt81's Avatar
Yep! Thanks for the correction. Something I even knew and still managed to use the wrong terminology. Middle age brain fart.
Now, if I can figure out how to change the post title...
Old 10-08-2018, 08:17 AM
ls777z
ls777z's Avatar
I guess I should have asked for clarification as well .....
Old 10-08-2018, 08:25 AM
WVZR-1
WVZR-1's Avatar
Received 2,254 Likes on 2,016 Posts
Reach out to a moderator and a 'title correction' won't be an issue. I avoided responding and maybe creating an issue when it was first posted.
To Repairing 88 door skin
Quick Reply: Repairing 88 door skin
