Cooling system flush?
89 with automatic
whats the the best way to flush all the crap out of the cooling system The liquid is brown, and I want out of there before I add new liquid. I want to flush the block as well as radiator
Mike
Mike
http://dieselgiant.com/mercedes_citrus_flush.htm
Pro Mechanic
Pull both KS's.
Pull the heater core hose from the water pump.
Fix a garden hose to the header core hose, run. This will backflush the heater core, intake, heads and block. Flush until water runs clear.
Flush the rad the same way until water runs clear.
Close system, fill, run it. Easy.
Pull both KS's.
In addition to the above suggestions, determine if you have 1 or 2 knock sensors located in the bottom of the block. They must be removed
as they are located in the 'sump' of the block. It will take great effort to dislodge the debris in the sump, either by water pressure directed into the
sensor holes, or with a wire. It is a messy job, but needs to be done.
Replace the sensors, inexpensive, and torque them to 14 ft# (important)
I think 89 has a KS but the other side has a nipple with a hose to the oil cooler that has to be removed to back flush
Pro Mechanic
An Important Public Service Announcement PSA, when working with radiator fluid:
http://www.humanesociety.org/animals...ntifreeze.html
Installed and tucked away. No clearance issues
Another shot after completion
Removed stock WSW reservoir and installed mini unit to make room for coolant housing and filter. Tapped into heater core feed.
tapped into the HC feed. Used two 90 degree fittings. Mounted the filter housing to the bracket on the blower motor housing.
