Sylvania SilverStar Headlight review
I upgraded from the Sylvania Cool Blue Headlights on my 96 to the new Sylvania SilverStar Headlights and there is no comparison between the two. It's as much of a change as it is going from standard "yellow" 6054's to the Cool Blue 6054's. The light is VERY white and has excellent coverage. Definitely a good upgrade to anyone who appreciates having ample lighting in front of them at night. Supposedly they are as close as you're going to get to HID's without the HID pricetag. :cheers:
Re: Sylvania SilverStar Headlight review (96VegasVette)
Cool deal, thx for the review. Something for me to think about when I go to replace my headlights.
Location: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
1 Post
Cool info! Thanks Allen! :cheers: :cheers: :cheers: By the way, I'm sure I've said this before many times... I want a hood ornament just like yours! Care to point me in the right direction? :lol:
Agreed! I put a set of Silverstars in my Tacoma first (simple bulb swap) before ordering the conversion for my 90 coupe. Will definitely be placing the order for the vette tomorrow.
Re: Sylvania SilverStar Headlight review (mpennabe)
I put a set of the 9003 Sylvania Silver Star bulbs in mine since I had already had changed my headlight fixtures in mine. These things are really bright :yesnod: If I had waited then I wouldn't have had to change my headlight fixtures out to accept the bulb type. :rolleyes:
Good Call 96VegasVette :cheers: I think everyone would want a hood ornament like that :eek: :eek: :eek:
Re: Sylvania SilverStar Headlight review (WEB_War84)
How hard is it to change the headlights? then i'd need to get them aligned
Its really easy and anyone can do it. When you remove the trim ring from around the headlight to remove it be careful not to move the headlight alignment screws. If you don't mess with them then you will not need to align the new headlight.
Re: Sylvania SilverStar Headlight review (CowboyNVette)
Well, they're already out of alignment
You don't need to order the conversion. They sell the Silverstar 6045 sealed headlamp assymblies now. $24.95 each at Autozone. :cheers:
Re: Sylvania SilverStar Headlight review (castivers)
Maybe that particular store doesn't carry them (depending on the size of the Store they may not carry the same product line as a bigger one down the street) The part number is 6054, can't remember what the last alpha digits were. Trust me though, they are out, sealed Sylvania Silverstar headlamps. They just got them in Thursday here. :)
Edit:
They aren't even listed as being available on Sylvania's website but I assure you, they are out. Give it a week, I'm sure they will filter down to your local stores. I trashed the boxes already, I can tell you this though, on the Cool Blue 6054's, on the glass the words Sylvania Halogen is stamped, while on the new 6054 Silverstar's the words Sylvania Performance is stamped. I'll go take a pic of what they look like on with the digi in just a min. :cheers:
Low Beam:
High Beam:
:cheers:
[Modified by 96VegasVette, 7:41 PM 10/28/2002]
Edit:
Low Beam:
High Beam:
:cheers:
Hope you are right and my area will soon have them. I couldn't find them on Autozone.com either. All I could find were the bulbs.
[Modified by castivers, 4:32 AM 10/29/2002]
If anyone is interested in these. I couldn't find them at my Autozone or at Autozone.com, but I did find them online at the Autobarn for $25.xx each. The part # is SYLH6054ST.
There was an extensive discussion about these in C5 tech last week. The response was varied, but most felt that upgraded bulbs are never much of an improvement. Take that for what it's worth, but I'd use caution before dropping $100 for 4 bulbs. :cheers:
http://forums.corvetteforum.com/zerothread?id=409232
Re: Sylvania SilverStar Headlight review (BQuicksilver)
I checked them out on Sylvania's chart which compared how much light their different lines of headlamps produced and the only 2 things brighter were Xenarcs and daylight. I'm not sure what you are talking about on the $100 for 4 bulbs. I spent $50 on 2 sealed beam headlamps.
As far as brightness goes, I'll clarify some. What most people are anaware of is that white light does not equal better visibilty. They often rate automotive bulbs by perceived brightness, which doesn't maean too much from a functional standpoint. I haven't tried the silverstars, but have used 3 different sets of top-rated bulbs, all of which looked very bright and white upon install and from head-on (as seen above), but they really were inferior to the stock yellow bulbs for road visibility. Aftermarket bulbs tend to disappoint for these reasons. Hope that helps you out. :cheers:
