C4 LT4 Years With Auto Trans?
What years of C4 LT4s came with an automatic transmission? I believe the 1996 LT4s only came in manual trans.
RetroGuy (11-04-2018)
LT4 never intended for automatic. It would need a least the 3.07 gear. A "loose" stall converter would simulate a manual in neutral when automatic is at idle in gear. Loose converters on the street, means you have to press accelerator just to creep.
In 1997, there were a limited number of Camaro's (100 , plus 6 for Canada) and even fewer Firebirds (29) with the LT4 engine.
Also all with a manual transmission only, but it wasn't the same ZF 6 tranny as the Corvette used.
The 97 LT4s all went through SLP. Into 30th anniversary SS Camaros or Firehawks.Their LT4 were all reworked or " Blueprinted" supposedly a little "Hotter" than the 96 Corvette engine.
