Valve Cover Emblem
Valve Cover Emblem
Was cleaning the engine bay today and when I was wiping down the passenger side valve cover I barely touch the round emblem on it and came off. Kind of glad it came off because loose as it was would have hated to have it fall off while driving down the road. Question is, what would you recommend I use to re-attach it that stands up to the heat and vibrations?
CorvetteRules (11-11-2018)
I have attached a few with black silicone RTV (gasket maker). clean and degrease, and a little dime size glob in the center, position, and let it cure -
Get some 3M Super weatherstrip adhesive. Clean the back of the emblem and the valve cover with some alcohol. Just use enough to cover the entire area on the back of the emblem. Let it set for a couple of minutes and then press the emblem on the valve cover. Been using this stuff for years.
