LS1 into C4
Old Oct 30, 2002 | 09:04 AM
STREETKNIGHT's Avatar
STREETKNIGHT
St. Jude Donor '03-'04-'05-'06-'07
Default LS1 into C4
I sure this has been addressed before, but my search didn't turn up anything. Has anyone here ever transplanted an LS1 into a C4 (87-88 model or?
Particular problems, suggestions, increases in performance?
Should I just rebuild and mod the L98?
Thanks for the information.
:cheers: :seeya :flag
Old Oct 30, 2002 | 11:25 AM
rainsux89's Avatar
rainsux89
Default Re: LS1 into C4 (STREETKNIGHT)
Everyone will tell you to mod the L98, but an LS1-C4 would be interesting to see. :eek:
Old Oct 30, 2002 | 11:29 AM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Re: LS1 into C4 (rainsux89)
Old Oct 30, 2002 | 12:00 PM
RadPolo96's Avatar
RadPolo96
Here is an engine for yah :cheers: http://forums.corvetteforum.com/zerothread?id=422430
Old Oct 30, 2002 | 02:09 PM
bogus's Avatar
bogus
I will use the surgical metaphor...
modding an L98 is like having your tonsels removed...
installing an LS1 in a C4 is like having your tonsels removed..... rectally.
The LS1 is nothing like the old 350... the bolts don't match... you would have to source a tranny... ouch... the mounts aren't the same... computer issues.
it is not an easy swap.
Old Oct 30, 2002 | 02:15 PM
vader86's Avatar
vader86
Default Re: LS1 into C4 (bogus)
It would be too much hassle, its easier to throw a big block in there.
Just mod the L98.
Old Oct 30, 2002 | 02:26 PM
zelement's Avatar
zelement
Default Re: LS1 into C4 (vader86)
There is a guy here from TX I think his screen name is 84 LS-1 or something, he supposely has a LS-1 stuffed in an 84. I haven't seen pictures or nothing but he is around here.
I have seen 3rd gen camaros with LS-1s stuffed in them, so you know it can be done.
[Modified by zelement, 12:27 PM 10/30/2002]
Old Oct 30, 2002 | 02:48 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: LS1 into C4 (zelement)
It can be done but it is really costly. You can get more power for less money modifying what you have.
Old Oct 31, 2002 | 02:03 AM
GDP's Avatar
GDP
The LS1 is a great engine, but let's really get down to what we all really want: An LS6 in a C4. :D
The swap can be done. Are we talking Corvette or F-body LS1? The best reason, really, is weight. Aluminum block vs. iron block... hmmm, I'll take the aluminum. Very lightweight, powerful, efficient, reliable engine. Be sure to attach it to a modern 6-speed tranny as well, probably one from a C5. Not sure if the stock C4 tranny can be attached to the LS1. I say go for it, and if you're going to do it, do it right. Get the LS6. :yesnod:
EDIT: Don't know how much an LS1 is vs. an LS6. Just speculating in my post here. :cheers:
[Modified by GDP, 12:04 AM 10/31/2002]
Old Oct 31, 2002 | 02:22 AM
DarkHalo's Avatar
DarkHalo
From: SCMR Rat Pack'r Charter Member, Inland Empire Chapter
I read all the replies and stick with my first impulse....mod the L98 dude!!! :blueangel:
Old Oct 31, 2002 | 05:00 AM
STREETKNIGHT
Default Re: LS1 into C4 (DarkHalo)
Yeah, you're probably correct. It was the LS1 engine out of a C5. Just thought it might be a unique swap. :rolleyes: . Moments of lapsed judgement I guess (or too much coffee, not enough sleep, all of the above :lol: ).
Guess I'll just mod the L98..............................OR maybe it's time for a stroker :cool:
Thanks for all the responses
Old Oct 31, 2002 | 06:59 PM
HWoods's Avatar
HWoods
TracerX in Houston dropped an LS1 into an 84. I believe he used one out of a Camaro due to oil pan differences. You can probably find him on the LS1 forum. He has an LS1 Firebird too.
Old Nov 1, 2002 | 09:50 AM
STREETKNIGHT
Default Re: LS1 into C4 (HWoods)
Old Nov 1, 2002 | 09:16 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
hate to be stupid azz here, but can i swap out just the injector assembly on a x-fire and get better power from the block ? :confused:
Old Nov 1, 2002 | 11:38 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VII Veteran
Or you can get really :crazy: & drop a C5R block in there... :yesnod: :seeya
Old Nov 3, 2002 | 01:06 AM
bogus's Avatar
bogus
Default Re: LS1 into C4 (barkingowl)
Ligenfelter can build you a 427" SBC Gen 2 (NASCAR) block for about $50,000.00!!!!!!! 600hp or so...
Car & Driver
check out that link :D
I have seen this car... it ROCKS...
[Modified by bogus, 12:10 AM 11/3/2002]
Old Nov 3, 2002 | 09:29 AM
388 SOLid RoLLeR's Avatar
388 SOLid RoLLeR
dont get an ls1. Aluminum is not reliable... GM is having problems with the block strength and cp strength even with 6 bolt caps. Lotta flexx. they even changed the bolts in 97s, then 98s, then 01s on the main caps due to flex. Lotta oil eating issues... so much more i wont start on
To LS1 into C4
Old Nov 3, 2002 | 10:14 AM
ittlfly's Avatar
ittlfly
Default Re: LS1 into C4 (388 SOLid RoLLeR)
Maybe that's why I decided to stay with my C-4 and not downgrade to a C-5. :lol:
Old Nov 3, 2002 | 02:25 PM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
[QUOTE]Ligenfelter can build you a 427" SBC Gen 2 (NASCAR) block for about $50,000.00!!!!!!! 600hp or so... [QUOTE]
coool :cool:
Old Nov 3, 2002 | 03:04 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: LS1 into C4 (ittlfly)
:lol: :D :lol: Well said!!! :lol: :D :lol:
