GENSSI headlamps - wrong pigtail connection?
I finally bit the bullet and bought some replacement headlamps (), but when they got here I was surprised to see that the pigtail has the wrong plug on it. Whereas the image on Amazon showed a H4 connector, which has three flat male prongs, the headlight showed up with something altogether different - this 3-pin female triangular plug, which as far as I can tell is for https://www.aliexpress.com/item/2-x-Genuine-OEM-Original-Triangle-3-pins-power-cord-for-headlight-leveling-motor-used-free/32791053251.html?
I messaged the seller, but it's been a few days, and I haven't heard back. I've also looked to see if I could find an adapter, but no luck. I can't even figure out a name for this triangular connector. In the meantime, do you guys know of an easy way to make this work without permanently altering wiring?
You got the wrong connector. Send them back or splice them in without the plug.
I wouldn’t touch any of the wiring on the car side. If you really want to make those work you might be able to find the correct wire harness at your local auto parts store (pep boys, Autozone, etc.) that you could splice on to the headlight. But of course if you cut off the plug that came on it to splice on a different one then you lose any chance of returning the lights. I’d wait to return the lights and get the correct replacements. The link you sent shows the correct plug, so they obviously messed up on their end.
If all else fails and you can't return them (or the picture is wrong) you can get pigtail adapters, such as this one:
you would need to ensure of the correct adapter, but they are available
I think you meant to say that some headlight packages contain a LOAD RESISTOR already added. FWIW, measuring the resistance across the high beam (in particular) to the ground terminal (on the connector) will tell you if you need the resistor or not, e.g., a reading of ~ ± 6 ohms and you're golden!
It would be helpful if the sellers would include this information in the description. I found out mine had the internal load resistor by plugging everything in and turning the switch. Then I did the "I don't have to stand on my head in the passenger footwell to fix the ground issue" dance.
So to take the VOM approach, you'll need to read resistance across the two up right spades in the U shaped plug.
Don't know how much the Genssi headlamps cost. Mine are under $90/pair now.
She's lit.
It seems that you imply you bought them through Amazon. Was it Speed Shop the vendor you bought from ? If so, follow the links and you end up here
and there will be instructions on how to initiate the return
https://www.amazon.com/GENSSI-Headli.../dp/B007AK9M66
https://www.amazon.com/sp?_encoding=...b=&vasStoreID=
Actually, it seemed fishy to me that the lights would have the wrong connectors when it seems like GENSSI is a pretty major company, so I messaged GENSSI asking if I could have possibly received a counterfeit item. Also seems a little off that they're $250 + shipping from the mfg only $190 on Amazon.
Nope, used a credit card through Amazon, so I'm not too concerned. Worst comes to worst I'll just return them.
Yep, Speed Shop is the one! Why, do they have a bad reputation?
IDK about Genssi lights but mine DID need the load resistor to get the fog lights/high beams to function as they should
Mine (the ones in the picture that don't look at all like Genssi) are a knock-off of the TruckLite bulbs. They run $89 a pair and the load resistor is built in. Which I discovered by plugging them in.
Here's the link to the bulbs I bought. Plug and go.
C4ProjectCar (01-23-2019)
If you paid $250 for a $190 item, I'd return it ASAP. I'd forget the Circuit Doctor mod. It is much easier to use THIS inline. I did and it worked. Didn't have to futz around with cutting and splicing a harness.
C4ProjectCar (01-22-2019)
After two unanswered messages to the seller in the past two weeks, I'm returning the lights. From the reviews, it looks like they are supposed to come with the H4 connector. Should I just re-order and hope I don't get defective units again, or does anyone suggest getting a different set instead around the same price point?
I suggest you actually order the Genssi from them itself unless you are willing to try another seller. It was cheaper for a reason. This is the reason. Aggravation.
I already gave you my best recommendation, and a link. But if you are hell bound to buy Genssi, I agree with Aklim. Return these and order direct from Genssi.
