Headlight options
Headlight options
Morning......I did a search on headlights and I saw a few threads out there...most of them were arguing back and forth about compliance, cut off, etc. That being said, there have to be some good options out there by now to replace the stock lamps....which we should all be able to agree are terrible at this point. So, a few questions......
-What are compliant / safe options out there that people have used?
-How complicated is the actual install? **aligning correctly to not blind people, etc.
-Are they now truly plug and play with factory operation of all lights?
-Are fog light upgrades needed?
I am looking for options that keep the stock flip ups!
Thanks in advance!
-Rick
Thanks in advance!
-Rick
Theres no set of answers that are right across the board. There are a lot of u it's on the market, with varying designs, brightness, etc.
I can only speak to the set I bought, they have good light output, and a great cutoff. They did require the foglight relay mod ro make everything normal. They're bright enough to. It need foglights, I chose to replace my fogs with actual foglights that have yellow light to be used in bad weather.
There are many other options out there. I dont think there is one option that is just all around better. Some dont need the foglight mod but have less output or a worse cutoff. Some have no cutoff at all.
You kind of have to decide what's important to you to choose them.
I bought these more than a year ago. Very happy with the results. Excellent cut off. Built-in load resistor provides stock fog light operation without mods. DOT approved. Very bright.
Aiming them is a process unless you have the tool. With the tool, it's a 5 minute job. You might need a DeLorean set to 1984 to get the tool though.
Lots of folks had to add resistance (to the later year C4s) or rewire the fog relay to keep the fogs working. Although they don't mention it in the product description, mine had the built in resistance.
Good luck!
Fogs from superbrightleds.com had to be modified with a file to fit.
Headlight alignment tool.
Here's what the cut off looked like on my garage door.
Good luck!
lol. all u need to align is a screwdriver.
i bought same as fuaee. they are awesome.
bfenty got them too. recent thread.
I used semi sealed beams with a replaceable Halogen H4. All the LEDs etc are arguable as to whether they are legal or not in all states or in my case in Australia. I know mine are compliant and I'm happy with them.
Thanks in advance!
-Rick
Thanks in advance!
-Rick
At the very least, your screwdriver would need a wall at one end of a very level spot with measured marks to aim for.
The tool pictured is placed beside the front tire and a bubble level is set. Then the tool is placed on the three aim points on the headlight showing exactly how much and what direction to turn the screwdriver.
sry renfeld i didnt mean to make it look or sound like i was scoffing at that tool.
No doubt im sure its a serious tool that makes it easier. Mostly i wanted to op to know its not necessary. just adjust then go drive and find a wall 10m out and the cutoff needs to be below (a bit) the height of the headlights. not higher. iow, not aimed up.
ive been adjusting mine a tonne and tweaking as i drive at night. when i first imstalled i got flashed once and i pulled over to lower them. problem solved.
There's a specific formula for getting the aim right with the wall method. I don't know it offhand because, well, the tool. But involves control of multiple variables. Level ground. Proper tire pressure. Half tank of gas. Distance to wall. Distance from level ground to aim point on wall. Ya gotta cover all the angles. Otherwise, you get flashed or maybe aim too low and don't get the full effect.
If I didn't have the tool, I would take them to the guy who does my alignments and have them aimed.
With aiming headlights. Most states with required safety inspections, the inspection stations will have headlight aiming equipment. The hardest part of aiming without aimers is finding flat level surface.
I have real headlights in my 87. They are Cibie e-code lamps with replaceable H4 bulbs. With off road 130/100w bulbs a relay kit and new headlight wiring is mandatory. They pull 18amps on low beam. As for light output they are very flat with a kick up on the edge of the road lighting up signs. On high beam it's like the sun came out.
Look for Daniel Sterns lighting, his page has some good info.
I don't have any experience with LEDs
I spent @ $200 with lamps, wiring and relay kit.
JS
JS
JS
JS
