"Warranty void if removed"
Old 01-20-2019, 09:09 AM
C4Newb
C4Newb's Avatar
Default "Warranty void if removed"
My '96 LT4 has, on the rearmost driver's side freeze plug, a thermal disc that says "warranty void if removed". These discs are designed to melt if you overheat the engine. I have seen these many times on rebuilt/re-manufactured engines but never on a factory install.
Does anyone know if they all have these, or is this an indication that my engine has been rebuilt/replaced?
Thanks!
Phil
Old 01-20-2019, 09:34 AM
mazdaverx7
mazdaverx7's Avatar
I have only seen those melt away discs on reman or junkyard engines. Are you certain your engine is not either?
Old 01-20-2019, 09:42 AM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
I'd certainly think rebuilt/used OR something 'other than' GM/OE>
You could always check the block for the VIN derivative that's on the left rear. VIN derivative (if it's there) could explain much.
Old 01-20-2019, 09:49 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Id agree with the rebuilt statement...but you never know. These cars are old thier history is almost impossible to tell anymore
Old 01-20-2019, 10:21 AM
C4Newb
C4Newb's Avatar
Thanks for the replies. I didn't get any real history on the car as I bought it off a used car lot. It easily could have been replaced at some point. I have the trans out to replace the clutch and the driveshaft has a 2002 build date decal on it, so it was replaced at some point. Will see if I can figure out the VIN derivative thing. I can't see the numbers on the passengers side front pad on the block where I'm used to looking for SBC numbers.
It appears to be a real LT4, at least it has LT4 heads, roller rockers, intake etc.
Again, thanks for the replies!
Old 01-20-2019, 10:50 AM
BillDurant
Support Corvetteforum!
BillDurant's Avatar
I have to admit I have removed bed pillow tags in the past
Old 01-20-2019, 10:12 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
NOOOOOOoooooooooooo
Old 01-20-2019, 11:07 PM
drcook
drcook's Avatar
Finalist 2020 C4 of the Year - Modified
Please don't tell the mattress tag police I removed them.
Old 01-21-2019, 07:59 AM
C4Newb
C4Newb's Avatar
You guys live on the edge!
So..........the VIN cross reference has had the original numbers over-stamped with X's, making the original number illegible but safe to assume no match.....
The number on the front pad, under the ICM is V1208ZXD.
Is there a source to decode that? I searched the forum but didn't get a hit......
I would just like to know what the shortblock is at this point, hopefully a Corvette one. It's got all the other visible LT4 parts.
Thanks!
Old 01-21-2019, 08:13 AM
RtStuf
RtStuf's Avatar
Corvette Black Book: ZXD: 350ci, 330hp, mt (LT4)
C4Newb (01-22-2019)
Old 01-21-2019, 09:03 AM
WVZR-1
WVZR-1's Avatar
Thanks!
The 'block' is LT4 w/ZXD but internals are still maybe questionable. It's safe to assume it's NOT a JY piece!!
Old 01-22-2019, 07:05 AM
C4Newb
C4Newb's Avatar
The engine is spotlessly clean inside and all the fasteners appear new and of the original GM type so I hope that indicates it was a GM exchange or rebuilt engine but I suppose there's no way to be sure.
It runs well and doesn't use oil or make any weird sounds so a bit disappointed that it doesn't match the car but at least it's a Corvette block.
Thanks!
Old 01-22-2019, 02:07 PM
Kevova
Kevova's Avatar
GM does not used overheat tabs. Vehicle history may give you a hint where to look. Remans normally have ID markings somewhere on them; so of there is a claim they know it's their engine.
To "Warranty void if removed"
Quick Reply: "Warranty void if removed"
