Cannot open doors with key
I have a 1993 that I recently acquired (5 days ago). Saturday it functioned perfectly. Sunday morning I walked up to the car and nothing happened. No lights came on on the inside, the doors did not unlock, etc. I tried to use the 'round' key to open the doors and it would not open either. I replaced the battery in the fob Sunday afternoon and still nothing. any suggestions? Thanks.
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
2020 C4 of the Year Finalist - Unmodified
2019 C4 of Year Finalist (stock)
What happened when you tried your round key? Does it just not turn at all? Can you wiggle and get it to go in either direction at all? If so, I'd inject some graphite into the keyhole and keep trying a little at a time. You certainly do not want to apply so much pressure that the key breaks off, though. Just FYI, when at the driver's door turning the key clockwise unlocks the door. Also, did you try the passenger door as well with it?
Guess I should have first asked, did you try the key before you bought the car? Do you know that it is supposed to work?
If a light stuck on or something and it drained the battery, there might not be anything wrong at all with your key fob. I have the same issue to fix with a friend's 93. Their battery died and the key won't unlock the door.
Try this for ha has and see if it works.
Jack up the car, correctly of course and put jack stands under it.
Let me repeat, put jack stands under it.
Put a battery charger + cable on the hot side wire to the starter and the neg side to the frame. If it is pulling a charge, let it charge a bit and then see if the FOB will open the door.
The following 2 users liked this post by Sprongs:
Paul Workman (01-31-2019),
slipup (01-30-2019)
I had surgery to repair a torn meniscus in my knee on Jan 20th. Event though I have felt better and we had a couple warm days, my friends won't let me work on their car until I am completely healed and it warms up outside.
I will post what I find out when I find out
results of cannot open doors
I got AAA to open the car and charge the battery so it could start. I took it to the local Chevy dealer and I was told they have it fixed. Will see tomorrow. They said something about a light had been left on. Thanks for your suggestions.
Same with my friends. I spoke to them today and they had the brilliant thought that their insurance covered it under the roadside assistance clause. Someone came out and slim jimmed the door for them.
they had an air bag that they slide beside the window glass and inflated it enough to get a flexible metal rod in and pushed the door lock open. Once we got it open he hooked up a quick start battery to the car battery and it started right away. Took it to a dealer to make sure there was nothing wrong.
Today we are supposed to hit 42, tomorrow 51, that will bring the temps of the motor up since we have been running below 0 temps here for a bit in Ohio and the metal in the engine (etc) is cold. I'll open the garage door tomorrow, warm it up and then Monday I'll test the scenerios out on my '96 and see what happens.
Of course I am going to open the hood :-). I am going to start it and let the battery charge up (I do every once in a while) and let the engine warm enough to get any condensation out of the oil. After this, I will lock it with the key FOB, both manually using the buttons and letting it automatically lock the car and then see if the key will open it.
I am going to do the same with my friend's car, even though they have it opened.
Maybe other folks can do the same and report back the results including the year of the car so it can be determined if there is a pattern to this.
What RIC96 is getting at (and what I was talking about in my reply above) is that the key is a manual process, not an electric one. Even if the battery is dead the key should unlock the car.
RIC96 (02-02-2019)
