Cleaning Aluminum parts?
What have you used to clean aluminum? I do not want to polish it I just want to remove the dirt and oxidation. I am thinking of things like the alternator body, water pump housing, the throttle body, AC compressor. I know there must be a mild acid that will clean it. Something I can use rubber gloves and a moistened rag. What am I looking for?
I have used "cleaning vinegar" and a brass brush or mild steel brush. Cleaning vinegar has a little higher percentage acid then regular white vinegar. Other mild acids work as you suggested.
Cleaning vinegar is available cheap at WalMart and is not too terribly harsh on your skin or your eyes if you happen to splash it.
I would give it a try first. That is what I am using on the Dana 44 housing I am cleaning/rebuilding.
Eastwood also has an aluminum cleaner, but it is expensive. It could be used as a final clean after using other products.
https://www.eastwood.com/ew-aluminum...er-bottle.html
Aluminum wheel cleaners are too mild to get much off I have found.
I agree with post #2. I used Eagle One cleaner on my front and rear suspension parts on my 84. I had everything apart and it did come out really nice. Looked like brand new when it was done. On some of the really greasy parts I used steel wool to help break through grease. Wear rubber gloves for sure and eye protection when using it.
Eagle One Etching Mag Wheel Cleaner
Received 3,043 Likes
St. Jude Donor '05
Careful using it on wheels that are clearcoated, it ate right through mine.
slipup (02-01-2019)
Buy the eagle one etching mag wheel cleaner now while you can. All of my local stores are discontinuing it! I think I can still get it on Amazon for now but once that supply is out I think its all getting replaced with this more environmentally friendly cleaner:
Any "aluminum brightener" will work. I bought Duragloss 551 on Amazon. A lot of options for boat hulls and RVs.
car addict (02-01-2019)
I use awesome orange from the dollar store, or simple green if not real bad, you can buy a gallon of concentrate for 10$ that will last a real long time, the green is pretty good for how non corrosive it is.
