Clear top re-do
I redid the clear top on my c5. Mine was not scratches it was the hard coat that had crazed and the sun damage was the problem. I wet sanded the hard coat off and then applied adhesion promoter first, then two coats of 2k clear. It took several hours of sanding The final result was well worth it to me. It has been four years and still looks great today.
I think you would be fine with your repair as you stated.
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
2020 C4 of the Year Finalist - Unmodified
2019 C4 of Year Finalist (stock)
I had scratches in my clear top. To get them out I had to sand through the hard coating. I just sanded all the hard coating off, buffed the top, and waxed it. That was a few years ago and it still looks fine with no clear coat on it.
Zen Vet Master Level VII
Yep, I did mine a couple months back. It took 90 minutes and came out great.
1) Tape off your roof while leaving it on the car. You don't want to buff (later) any part of your paint
2) Wet sand with 1500 twice. Wipe when finished
3) Wet sand with 1000 twice and wipe when finished.
4) Buff (get a machine) with a super fine glaze cutting compound. I did mine twice then wipe.
5) I had waxed, using a liquid wax. Again, twice.
It came out super nice. I'm totally happy.
On my 96 I have the "Bronze Roof Panel" (RPO code 64S). It looks like attached pic (a little hard to see, but it's there). Is this what yours looked like before you started?
puterami (02-03-2019)
Check out this thread - I used Bar Keeper's Friend and a buffer on my clear top and you can see the results for yourself:
https://www.corvetteforum.com/forums...ned-glass.html
