377 vs 383
Really should stick to OP original question. Throwing LS etc into it is apples and oranges. Different mains and many other items affect this. Keep it to 400 destroked or 350 stroker for comparisons. JMHO.
As already noted, it would be stupid to destroke a 400 unless a race class's rules require a lower displacement limit. If the OP wants to keep his block and is willing to spring for a 3.75" crank, then he will definitely get more power and great reliability out of it. If he is willing/able to start his build with a 400 block, then by all means he should build it as a 400 (or go even bigger with a longer stroke). When seeking power, there is never, ever a case where more displacement isn't better as long as the rules allow it. I assume that the OP (who, btw, hasn't come back to his own thread in 35 hours) is just doing a street build, where rules don't apply. For him, a 377 is stupid. A 383 is good, a 396 is better, and a 400+ is even betterer.
I'm wondering what the point is here? How does this relate to this thread? You are totally right; With enough age and miles weak links show up that may never be an issue in the first 5-10 years. Ayuh. But....(?)
Dtto here. What's this got to do with a 377 (destroked 400) vs. a 400 crank in a 350?
Who disputed that...or even brought it up? Talk about making your own issue to debate!
well I quoted the reference to the 8000 RPMS.
There is discussion up above about stroke vs. Bore and RPM.
Matthewmiller was stating his case based on the fact production cars have a certain capability, I was pointing out there have been lots of designs that work initially and don't stand the test of time.
Seem you have a bit of a problem. There is an ignore function. Feel free to use it.
Pro Mechanic
Right, a 383 and a stock 400 both use the same crank with a 3.75" stroke. All I can say is that the empirical evidence suggests that in the year 2019, there are plenty of engines with much longer strokes than 3.75" that are revving to the moon. As Tom mentioned, plenty of 3.75" SBCs rev safely way above 8000rpm. Chevy's own LS7 had a 4" stroke and came in mass-produced vehicles with a 7000rpm redline and a warranty. And companies like HPR routinely sell LS engines with 4.25" strokes (and more!) that can safely go past 8000rpm.
There's simply no good reason for a 3.75"-stroke engine to be rpm-limited by its rotating assembly. This obviously depends on the parts one specifies: a stock 400 rotating assembly isn't good for 8000rpm, but then neither is a stock 350 rotating assembly. I'm going out on a limb to suggest that any build the OP is considering would not entail rpms that a stock 400 rotating assembly couldn't handle. It's probably going to be kept to a 6000rpm redline, and that is uber-safe for any of these assemblies.
Pro Mechanic
I don't see how the stroke to bore ratio affects longevity*. Piston speed, rod angle, side loading....is all about the same, for the same stroke (all else equal). Going from a 383 to a 400....how does the 400's bigger piston make it "more reliable" or longer lasting? Is a 350 more reliable or longer lasting than a 305? They both have the same 3.48" stroke, but the 350 has a better bore/stroke ratio. What am I missing, here?
*As it relates to this discussion. I "get it" that a short stroke engine -one with say, a 2" stroke is going to create less wear and stress at a given RPM...here we're talking about 383's and 400's...both of which have 3.75" stroke.
What you are not taking into account is stroke to bore ratio which is important in determining rpm limits and longevity of a motor. Sure a 427 has the same 3.75 stroke as a 383 and can rev to 7000. But its larger bore makes for a more square stroke to bore ratio allowing it to rev easier. An extreme example is a formula 1 motor. It can rev to 18,000 rpm because it's stroke is only 1.566" while it's bore is only about 1/8" smaller than a 350 block. This allows it to achieve 8000 hp with 2.4 liters. I'm not saying a 383 can't be made to rev to 8000rpm, but the bearing friction increases due to the speed and weight of the piston and reliability becomes compromised. That is why a 383 is considered a motor more for the street or heavy duty applications than a motor commonly found at the track. Don't get me wrong, I am in no way knocking a 383 motor; I ran one for years at the strip and shifted at 6200 rpm. I am now running a 406 and shifting at 6700.
350 block with a 400 crank or a 400 Block with a 350 crank. Same displacement, different stroke lengths.
The 350 with the 400 crank would lend itself to be a higher torque lower rpm motor
The 400 with the 350 crank would lend itself to be a higher horsepower engine that would rev easier.
That is not to say both couldn't run 7500-8000RPMs, both built well with quality parts and proper clearances should last.
There is the anecdotal reliability we all need. Which is will the motor serve us well and will not fail on us. Then there is reliability testing. Both engines mentioned are more than likely capable of lasting many years, hours, or miles of use. I would say, if both motors were put on a dyno and ran at 7500RPMs to failure, the 400 with a shorter stroke should last longer. However, I believe there are way too many variables long term that affect reliability other than just stresses on the bottom end. Especially in a boosted application where detonation can blow a hole through a piston. There are a lot of things that can go wrong and cause a motor failure. Neither a stroked 350 or destroked 400 are pushing the extremes where wither is failure prone. So if the destroked 400 can last 500K hours at 7500RPM and the stoked 350 can last 450K hours... are either a bad motor? No Are either considered prone to failure? No.
Pro Mechanic
Same stroke is the same piston speed at a given RPM, So no change. All the same loading except the piston weight. Looking at a bore to stroke ratio for reduced stresses wouldn't be between two different displacements utilizing the same stroke. It would be to say, as I mentioned above, there are two ways to get a 377.
There is the anecdotal reliability we all need. Which is will the motor serve us well and will not fail on us. Then there is reliability testing. Both engines mentioned are more than likely capable of lasting many years, hours, or miles of use. However, I believe there are way too many variables long term that affect reliability other than just stresses on the bottom end. Neither a stroked 350 or destroked 400 are pushing the extremes where wither is failure prone. So if the destroked 400 can last 500K hours at 7500RPM and the stoked 350 can last 450K hours... are either a bad motor? No Are either considered prone to failure? No.
For the purpose of this discussion, the OP is fine with either. Destroking a 400 to a 377 for the sake of reliability is Worryin' about chit that ain't worth worryin' about. SO....if the OP's friend thinks that a 3.48 stroke 400/377 is going to be "more efficient and reliable" than a 3.75 stroke 350/383....then the friend is up in the night, and the OP should either:
1. reuse the 350 block that he already has or
2. take that same 400 block that he would have to acquire to build the 3.48 stroke 377 and build a 3.75 stroke 400 and enjoy ALL 400 cubes, for a long, long time.
For your reading enjoyment...
Tech Talk #53 – Big Bore or Long Stroke: Which Is Better?
By David Reher, Reher-Morrison Racing Engines
“An engine produces peak torque at the rpm where it is most efficient.”
Recently I’ve had several conversations with racers who wanted to build engines with long crankshaft strokes and small cylinder bores. When I questioned them about their preference for long-stroke/small-bore engines, the common answer was that this combination makes more torque. Unfortunately that assertion doesn’t match up with my experience in building drag racing engines.
My subject is racing engines, not street motors, so I’m not concerned with torque at 2,000 rpm. In my view, if you are building an engine for maximum output at a specific displacement, such as a Comp eliminator motor, then the bores should be as big as possible and the stroke as short as possible. If you’re building an engine that’s not restricted in size, such as a heads-up Super eliminator or Quick 16 motor, then big bores are an absolute performance bargain.
I know that there are drag racers who are successful with small-bore/long-stroke engines. And I know that countless magazine articles have been written about “torque monster” motors. But before readers fire off angry e-mails to National DRAGSTER about Reher’s rantings on the back page, allow me to explain my observations on the bore vs. stroke debate.
In mechanical terms, the definition of torque is the force acting on an object that causes that object to rotate. In an internal combustion engine, the pressure produced by expanding gases acts through the pistons and connecting rods to push against the crankshaft, producing torque. The mechanical leverage is greatest at the point when the connecting rod is perpendicular to its respective crank throw; depending on the geometry of the crank, piston and rod, this typically occurs when the piston is about 80 degrees after top dead center (ATDC).
So if torque is what accelerates a race car, why don’t we use engines with 2-inch diameter cylinder bores and 6-inch long crankshaft strokes? Obviously there are other factors involved.
The first consideration is that the cylinder pressure produced by the expanding gases reaches its peak shortly after combustion begins, when the volume above the piston is still relatively small and the lever arm created by the piston, rod and crank pin is an acute angle of less than 90 degrees. Peak cylinder pressure occurs at approximately 30 degrees ATDC, and drops dramatically by the time that the rod has its maximum leverage against the crank arm. Consequently the mechanical torque advantage of a long stroke is significantly diminished by the reduced force that’s pushing against the piston when the leverage of a long crankshaft stroke is greatest.
An engine produces peak torque at the rpm where it is most efficient. Efficiency is the result of many factors, including airflow, combustion, and parasitic losses such as friction and windage. Comparing two engines with the same displacement, a long-stroke/small-bore combination is simply less efficient than a short-stroke/big-bore combination on several counts.
Big bores promote better breathing. If you compare cylinder head airflow on a small-bore test fixture and on a large-bore fixture, the bigger bore will almost invariably improve airflow due to less valve shrouding. If the goal is maximum performance, the larger bore diameter allows the installation of larger valves, which further improve power.
A short crankshaft stroke reduces parasitic losses. Ring drag is the major source of internal friction. With a shorter stroke, the pistons don’t travel as far with every revolution. The crankshaft assembly also rotates in a smaller arc so the windage is reduced. In a wet-sump engine, a shorter stroke also cuts down on oil pressure problems caused by windage and oil aeration.
The big-block Chevrolet V-8 is an example of an engine that responds positively to increases in bore diameter. The GM engineers who designed the big-block knew that its splayed valves needed room to breath; that’s why the factory machined notches in the tops of the cylinder bores on high-performance blocks. When Chevy went Can-Am racing back in the ’60s, special blocks were produced with 4.440-inch bores instead of the standard 4.250-inch diameter cylinders. There’s been a steady progression in bore diameters ever since. We’re now using 4.700-inch bores in NHRA Pro Stock, and even bigger bores in unrestricted engines.
Racers are no longer limited to production castings and the relatively small cylinder bore diameters that they dictated. Today’s aftermarket blocks are manufactured with better materials and thicker cylinder walls that make big-bore engines affordable and reliable. A sportsman drag racer can enjoy the benefits of big cylinder bores at no extra cost: a set of pistons for 4.500-inch, 4.600-inch or 4.625-inch cylinders cost virtually the same. For my money, the bigger bore is a bargain. The customer not only gets more cubic inches for the same price, but also gets better performance because the larger bores improve airflow. A big-bore engine delivers more bang for the buck.
Big bores aren’t just for big-blocks. Many aftermarket Chevy small-block V-8s now have siamesed cylinder walls that will easily accommodate 4.185-inch cylinder bores. There’s simply no reason to build a 383-cubic-inch small-block with a 4-inch bore block when you can have a 406 or 412-cubic-inch small-block for about the same money.
There are much more cost-effective ways to tailor an engine’s torque curve than to use a long stroke crank and small bore block. The intake manifold, cylinder head runner volume, and camshaft timing all have a much more significant impact on the torque curve than the stroke – and are much easier and less expensive to change.
#33
Pro Mechanic
Ayuh.
Copy all of that. Still not seeing the 383/400 diff as it relates to reliability... but I see the big pic of bore/stroke.
#34
Picking the cubes is the easy part....matching the intake, cam, heads, rr's, headers, exhaust, gears, flywheel, trans, tune, etc, etc, etc... is the real heart of the matter.
Then you have to ask your self was it all worth 450-500hp? (maybe more, but is it streetable) in a C4....
Will the car like to stop going faster? Will it accelerate straight with more power? Will it hook? Will you be comfortable with more power in it? Will your tires accommodate? Will your other parts hold up in the driveline?
Power sounds fun. it is expensive one way or another. A motor swap is one thing, a build in another.
#36
Assuming that you can find an original 400 c.i. block, and at this late date, good luck with that, or you're willing to pony up for a large bore aftermarket block, which solves a lot of other problems, like providing priority oiling, 383 / 400 pistons, unless you use the oem short 400 rods, as the rod length goes up to 5.7 or 6.0 inches the piston skirts become much shorter, and, especially with 6.0 inch rods, the ring pack is compressed to the point that I would question it's effectiveness in a street engine; blasting down the strip a quarter mile at a time, okay, regular, extended use on the street, maybe not so desirable.
#37
just put a ''BIG BLOCK CHEVY'' in it,,454-632ci,,it will get out of its own way then
or go find a ''SB2'' ex nascar engine,,if you look around there for sale for $5-10k
#38
I am still not buying the original more efficient statement. I still think more displacement is king except for when weight becomes and issue. I wouldn't opt for a big block just to get more cubes in a street car, but I would always opt for the bigger small block displacement.
#39
Pro Mechanic
#40
I was once told by a very experienced drag racer "You build the car from the back to the front". As to some of the things you are mentioning, the best engine in the world is worthless if you can put the power to the ground and control it.
