Regular gas vs Premium in Lt1
Old 02-12-2019, 02:40 PM
Tom400CFI
CF Senior Member
Tom400CFI's Avatar
Originally Posted by mto View Post
Probably run OK, but it can cause carbon build up bc not enough additives. I would only use top tier gas that is a premium. https://www.toptiergas.com/retailers/
I wasn’t clear. Any 87 fuel does not have enough additives. 93 does have proper additives.
That said, all 87 fuel is the same. One top tier and another 87 top tier, no difference. With 93, most top tier differ each other by additives and marketing.
I think that you might want to do a little learning about this topic. I'd recommend that you start by reading THIS THREAD....Look at the pictures in that thread....LOOK.
Tom400CFI is offline
Old 02-12-2019, 02:42 PM
Tom400CFI
CF Senior Member
Tom400CFI's Avatar
Originally Posted by aklim View Post
[h2]According to Top Tier, it seems like regardless of what octane, it should have the same additives since it is a standard
Bingo. EPA mandated. doesn't matter what octane level you choose...the minimum requirement (for detergent) is better than good enough.
Old 02-12-2019, 02:52 PM
coletrickle35
CF Member
coletrickle35's Avatar
They use a lot of high-test gasoline at the speedway but for day-to-day driving I'd say you will be alright
coletrickle35 is offline
Old 02-12-2019, 02:56 PM
aklim
CF Senior Member
aklim's Avatar
Do you know if the track fuel has any additives, assuming that is important to you?
aklim is offline
Old 02-13-2019, 12:36 AM
coletrickle35
CF Member
Whatever they put in Sunoco fuel
Quick Reply: Regular gas vs Premium in Lt1
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
