Double DIN radio that fits 94-96 trim
Old 02-16-2019, 08:19 PM
Matt92vette
Junior Member
Default factory radio and speakers
Just for anyone that's decides you want to keep the Bose system . There is a business in Florida that will repair Bose system and and year over 90 I think will warranty the components for a lifetime. I had my Bose amps repaired all for 320$ and the factory system sounds better than a thought. Got a bluetooth /fm transmitter from amazon and phone and music plays through radio . adapter plugs right into cigarette lighter.Just passing that on.
Matt92vette is offline
Old 02-16-2019, 10:19 PM
belairbrian
CF Senior Member
belairbrian's Avatar
Started the install of the pioneer. The fit is good, and everything checked out. I'm redoing the panels before I put them on. PO had glued chrome initials to the radio bezel.
belairbrian is offline
Old 02-16-2019, 10:50 PM
Maldini
CF Senior Member
Maldini's Avatar
Originally Posted by TorchTarga94 View Post
I used a rat tail file to trim the top corners just a tad, like others have said, you can't see it once installed. I don't believe I bipassed anything, I used the wiring adapter that came from crutchfield.
Might be a dumb question to ask, but how did the Sony mount in the slot for the factory radio? Did you need to buy some sort of fill kit or dash kit?
This is what I'm referring to.
Maldini is offline
Old 02-16-2019, 11:35 PM
belairbrian
CF Senior Member
I used the Metra 99-3051. It works for single and double din. For double din you only use the two side pieces
Old 02-17-2019, 12:05 AM
Maldini
CF Senior Member
Maldini's Avatar
Perfect, I just ordered the same one. Thanks everyone.
Maldini is offline
Old 02-18-2019, 08:04 AM
jmgtp
CF Senior Member
I ended up with a different Boss unit, for just slightly more this one has navigation as well. It had the same problem as the prior unit and didnít fit. I ended up filing the corners of the plastic trim to be square (they were rounded) and that was just enough for a fit. I didnít want to do that mostly because the piece was vinyl wrapped and due to its complex curves and multiple open slots was a really time consuming process to wrap.
jmgtp is offline
Old 02-18-2019, 04:50 PM
gpierce
CF Senior Member
gpierce's Avatar
Here's the single din Alpine unit, this is another option
https://www.alpine-usa.com/product/a...-auto-ilx-f309
gpierce is offline
Old 02-21-2019, 04:30 PM
CVG323
CF Senior Member
CVG323's Avatar
Originally Posted by gpierce View Post
I'd go with that if I had to do it again
CVG323 is offline
Old 02-21-2019, 05:37 PM
TorchTarga94
CF Senior Member
TorchTarga94's Avatar
The Sony is a Single Din Chassis with a double din screen as well and also has a volume **** not just up/down arrows for volume.
TorchTarga94 is offline
Old 02-22-2019, 05:13 PM
CVG323
CF Senior Member
CVG323's Avatar
ignore SRC light
CVG323 is offline
Old 03-11-2019, 06:50 PM
belairbrian
CF Senior Member
Finally got it back together.
Ended up with the USB in the center console. I can connect it and close it, Nav system is still fine even under the carport.
Quick Reply: Double DIN radio that fits 94-96 trim
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
