Battery removal question
Old 02-24-2019, 08:46 PM
turbobuick33
turbobuick33's Avatar
Default Battery removal question
Currently my vette is in storage and I'd like to remove the battery and charge it before I start it up next month. The lower 10mm bolt, will a regular size 10mm wrench fit in there? Or do I need a thin profile wrench? Just curious, I haven't gotten a chance to look into it yet.
Old 02-24-2019, 09:44 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
I use a low-profile wrench as the gap is indeed narrow, never tried a regular thickness wrench.
Old 02-24-2019, 09:48 PM
CorvetteRules
CorvetteRules's Avatar
I have used a "regular" wrench, but can say it was a tight fit.
Old 02-24-2019, 10:19 PM
Crossed Flags Fan
Crossed Flags Fan's Avatar
I just gently bend back the panel me on my 95.
Old 02-24-2019, 10:24 PM
Yukon Corleone
Yukon Corleone's Avatar
C4 of Year Finalist (stock) 2019
Originally Posted by ihatebarkingdogs
I don't remove the bottom bolt. I lift the battery up on end, and gently flex the panel out of the way. Probably changed the battery at least 15 times since I bought the car new, and haven't broken the panel yet.
i do it the same way but have only done 3-5 since I bought it new 29 years ago.
Old 02-25-2019, 05:47 AM
turbobuick33
What brand low profile wrench?
Old 02-25-2019, 06:13 AM
mazdaverx7
mazdaverx7's Avatar
I use a standard 10mm Snap On wrench and loosen the bolt a few turns and the panel slides right off. When I reinstall the panel, the lower bolt is the last to get tightened and it's only a couple of turns and its snug enough to hold the panel in place. I've never had an issue doing it this way.
Old 02-25-2019, 08:09 AM
bac22
bac22's Avatar
I'm not going to say it's a hassle, but removing the battery in a vette compared to other cars is a PITA. Also putting it back in, you'll spend 10 minutes re-aligning the panel correctly, although some of that time might be because my OCD kicks in and I need the panel to be perfectly aligned!
If the negative lead on your battery was disconnected, the battery shouldn't have lost much of a charge over the last few months of storage. But what I do is use a lithium jump starter after storage to help any lose of charge in the battery...plus it's an great emergency if you find yourself with a dead battery because a light was left on. I use a
NOCO Black Boost Plus GB40 NOCO Black Boost Plus GB40
, little pricey but worth it.
On a different note, I was actually able to start my car (96 LT4) with the GB40 alone...battery completely disconnected! Won't go anywhere without the GB40 in the storage compartment!
Old 02-25-2019, 10:13 AM
hcbph
hcbph's Avatar
I will mention something here I ran into. When I bought my 86 and needed to replace the battery I ran into an issue. The Bubba that last had that panel off put the panel tab between the bolt head and washer then they tightened it down. A Craftsman 10 mm would not fit through the gap, I did find though a HF 10 mm would. It was a bear getting hold of the head of the bolt to loosen it up, taking maybe an hour of failures before I finally got a hold on the head and got it loosened up. Once I had the bolt loose and the panel off, I've made sure to never do it that way again.
Old 02-25-2019, 10:26 AM
Paul Workman
Paul Workman's Avatar
What am I missing here? Why would one need to remove the battery to simply charge it, if that is all you're going to do?. Course if you want to service the connections, I could understand removing it...maybe. (That said, I've removed the terminals and cleaned them too w/o removing the battery. Removing is the much easier way to do it tho.)
Old 02-25-2019, 10:31 AM
ghoastrider1
ghoastrider1's Avatar
I let mine sit all winter. The battery is dead. Which side is the ground on? dont want to pull the panel. For reasons I forget, I once charged the battery by putting positive on the hot starter bolt and grounded it to the frame. Use Caution if you try it this way.
Old 02-25-2019, 11:16 AM
rocco16
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Try removing the battery in a 2012-on Jeep Grand Cherokee SRT... The C4 is a piece of cake by comparison.
Old 02-25-2019, 11:19 AM
novaks47
novaks47's Avatar
You can also widen that gap. Just loosen the two bottom most screws in the fender liner, and then loosen one or two bolts on the bottom of the lower skirt, and it'll drop down.
ghoastrider1 - Red is positive, black is negative/ground. Ground side is closest to the body panel.
Old 02-25-2019, 12:20 PM
mazdaverx7
mazdaverx7's Avatar
The ground is the outermost cable. The one closest to the removable panel.
Old 02-25-2019, 01:09 PM
JBPC4
JBPC4's Avatar
Is there no electricity where the car is stored so you can’t just charge it in the car? I don’t think getting the battery out is all that bad, I didn’t time myself when I replaced the battery last year but I don’t recall it taking more than 10 minutes or so start to finish.
Old 02-25-2019, 05:41 PM
Joe K
Support Corvetteforum!
Joe K's Avatar
2022 C4 of the Year Finalist - Unmodified
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (appearance mods) 2019
If you have a grinder you can just buy a cheap wrench and grind it to fit.
novaks47 (02-26-2019)
Old 02-25-2019, 06:35 PM
Yukon Corleone
I am replacing my battery soon. If you want to see how I do it let me know. I am not too far away from you. I am at 75th and Lemont Road in Downers Grove.
To Battery removal question
Old 02-25-2019, 09:16 PM
65Z01
65Z01's Avatar
My thin wrench is a Craftsman as that is all I bought about 20yrs ago when I got my 1st C4.
Old 02-26-2019, 11:46 AM
92ragtop
92ragtop's Avatar
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
And that is the simplest solution. I have a ground-down 10mm in my toolbox for just that reason.
Old 02-26-2019, 11:56 PM
gpierce
gpierce's Avatar
I have a regular old Craftsman, and fits fine. No grinding required
Quick Reply: Battery removal question
